Sytemrockr559 Posted April 5, 2017 Author Report Posted April 5, 2017 I have a Tugboat DNA 200 Buttons are unresponsive it turns on fine an charges When I hook it up to EScribe I can get it to fire using the serial commands But I notice when it's hooked up to EScribe it starts cycling through profiles on it's own Does anyone have any suggestions on how I could fix it
Spector NS5 RD Posted April 6, 2017 Report Posted April 6, 2017 hi, Sytemrockr559. sounds to me like you have a stuck button/faulty button(s). at the bottom of Device Monitor, you'll see "Buttons". does that field display any buttons being depressed when not pressing any of the buttons? it should say "None" if you're not.you could also have ejuice on the board.
Sytemrockr559 Posted April 6, 2017 Author Report Posted April 6, 2017 I'll check that out later when I'm home Now if that is the problem is that something I can fix myself?
Sytemrockr559 Posted April 7, 2017 Author Report Posted April 7, 2017 so it does show my up button sticking but not continuously just when i press other buttons
Spector NS5 RD Posted April 7, 2017 Report Posted April 7, 2017 if there is a warranty that is still in effect from flawless, i would contact them first. if you know the warranty is out, you can take out the board and try cleaning the affected button(s), with some iso alc. the top of the buttons do pop off. they're latched on both sides. make sure to not let the actuators spring across the room when removing. make sure there's no ejuice laying on the board, inside or around the buttons.another option is to de-solder the board from the mod and send it to evolv for replacement. one year warranty on the board from evolv.
