wiccaman48 Posted April 21, 2017 Author Report Posted April 21, 2017 Please can anyone advice me the battery bar stays full charge .but the % indicator goes down .can it be fixed .I am using Samsung 25r I think I set all setting correct .
giz_60 Posted April 21, 2017 Report Posted April 21, 2017 Here is the .csv for the 25r's.... Samsung_25R (2)_18650_2500 mah_16.92Wh.csv See if loading this helps you out...Edit: Make sure to set your Wh's to 16.92 or 17 then upload to device...
wiccaman48 Posted April 22, 2017 Author Report Posted April 22, 2017 Hi just let you no I have set the wh.csv to 16.92 .it seems to have worked and its now charging .which it did not do before.can tell me if its better to charge the batterys through the mod or a separate charger.i also use BROWN L.G. 3000 MAH the calculater is coming out with 22.2 is this number correct for theses batterys .Thank you for your help .
