Fumblefingers401 Posted April 27, 2017 Author Report Posted April 27, 2017 Is it possible to wire a light emitting diode (lighted momentary switch) so that it lights up when the dna 250 screen is lit rather than just when the mod is fired? I apologize if I missed some easy answer on Google for this..
Spector NS5 RD Posted April 27, 2017 Report Posted April 27, 2017 Fumblefingers401 said:Is it possible to wire a light emitting diode (lighted momentary switch) so that it lights up when the dna 250 screen is lit rather than just when the mod is fired? I apologize if I missed some easy answer on Google for this..it might be possible. You would have to probe the end of the screen ribbon flex connector on the board to find Vcc and Vss (pos and neg). Solder on tiny wires to the corresponding spots and run them to the LED. Just know the voltage that powers the screen is variable. This is voltage depends on your screen brightness level and fade in-out settings. This might also void your warranty, soldering to points in the board that aren't supposed to be soldered to.
Fumblefingers401 Posted April 27, 2017 Author Report Posted April 27, 2017 That's what I was thinking and I don't want to do that but I was hoping there was something I missed. Thanks for the reply!
