            Azax
                Posts13
Everything posted by Azax
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color no, i build coils at around cold 0.5ohm (mostly all of them) and all of them act strangely. i ll explain the whole procedure: i remove the atty, dissasemble it,remove coil(0.5ohm),wash it and let it dry. the settings on the device are tc 316 30w 260C preheat 45. i build another coil with the same wire same id same wraps, i get around 0.495-0.505 ohm on the ohmmeter, install everything and put the atty on the device. next i let the device cool down, resample the coil and start vaping but my old settings (30w,260C,45preheat) are too aggresive, so i need to lower the temp to 170C+. i vape a couple of days and start building another coil, same wire, same ohm and the device is too soft to boil the liquid so i invrease back to 260C.. it's werid
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color Hello guys,i have found out some inconsistency in coil/ohm read. i use the same wire for my coils around 0.3-0.5ohm depends on the day. but i ve started to use mostly 6,5 wraps and i read 0.5ohm. good till now, when i put the atty back on the mod, read cold ohm and start vaping but sometimes it wants me to vape at 260C, sometimes 180C.. and i don't know why, i m doing the same thing over and over and device monitor shows Wattage is going all the way up 20w+ when sometimes it never goes beyond 15W.. dunno what is going on. now i m on 180C and it basically feels like 260C-280C
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color got my new wires, suddenly everything is back to normal.. washed the tank in vodka, gave it some fresh clean (air compressor) and dried with paper towels.. now i have imported a 316L csv into the system and enjoying it. 8 wraps 28 awg 2.5id SS316L. i m having a problem in sweets/dessert department cause i get gunk in a day.. guess i m gonna always go dna <3.
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color i had the same coil as before, and that was the last coil to check, now i m on wattage and clapton atm till my ss 316 arrives. i did nothing besides restarting the device to default and installing the theme again, had the same coil, same settings but somehow the Watts were not going 24W like before, was dropping to 12-15.. i ll keep you posted after the new wire arrives. Thank you for your time.
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color guys, i ve encountered a problem. i ve reseted the device, installed the theme once more and i ve started vaping and found out that it's weird.. then went to device monitor, and i have the same settings as the old profile, my watts won't go beyond 13-15W.. what did i do? or what i did before?
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color thank you. may i ask how do you get that preheat time limit?
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color dunno if i can get those settings as genS but for sure now i can vape what says on bottle, such as all notes and not only one intense.. guess i ll play with it more. oh alright. i don't get cheap at juice, i smoke for pleasure. i understand, i thought ppl were monitoring battery just to get them through more days and chain vaping.. guess going through 15-20ml a day isn't a battery problem then. now i m vaping at 230C 30W and preheat 45 and punch 7. anyone else's settings (for simple SS coil) i'd apreciate; or any other coil which fits in evl reaper v3 + settings. thank you guys a lot <3.
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color oh, thanks a lot for the preheat advice. and for the battery, i mean when i puff, should i stay in a range of 5-7mwh? press less the fire button, or anything like that? i see people praising the dna for keeping their 21700 going for days.. my 21700 goes at best 12-16hours, and 18650 x2 per day.
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color let's say i have SS 316 profile with 220 C and under temp i have wattage which is set to 60W, then in this profile i have a preheat option, it's not a profile, it as an option > so if i enable preheat, does influence the profile? or ignores the profile with temp + wattage and just preheats. alright, i ll go 260C again. yes i did, and felt it was taking longer to heat. maybe just my imagination. also, i saw my battery sometimes ranges from 5-15mwh, what's the optimal discharge?
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color 1# if i set 220C + 60W on profile, then go to Preheat (i use hyperion-odin profile theme) i can set there another Wattage + punch level. does this stack with the profile? i saw 220C was safe to not get gunk/little black dots on muji cotton, usually i'd prefer it at 260C but i think it's not safe for SS at that temp.
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color i am on MTL conversion evl reaper V3Ti, simple ss316 spaced coil, but the vape is (if i compare to my old mod gen S) something like either 30% of what i ve felt, either this is blowing other notes which i couldn't get with gen S, but i can't get the flavor i had on GenS.
	  Need a little help with my Thelema DNA 100cAzax replied to Azax's topic in DNA 75 Color and 100 Color "Can you post 2 screenshots for me. The first being a Device Monitor while firing with the 'Power', 'Power Set', 'Cold Ohm' and 'Live Ohm' checkboxes enabled. The second being the Profile you're using. When you start escribe THAT profile # is shown as 'Current Profile'." yes, it is first dna device. cold ohm you mean first vape after letting it cool down and live ohm, the next vapes after cold? "When not using TC, so straight watts, how many watts are you using for an enjoyable vape?" usually around 18-24W.
	Hello. i m vaping on a thelema dna 100c with evl reaper v3 0.3mm id, 5 wraps, .303 resistance,SS316 26awg. i am looking for help cause in the manual it's not settings, no instruction, nothing really besides buttons and battery safety. regarding TC 316 : i let the coil cool down at temp room, then resample it and leave it unlocked(if i lock it, set temp to 260C but won't reach more than 155C so i leave it unlocked). set wattage mode to 90W and temp mode to 260 ( this is the only reasonable settings i got but still i get 30% of flavour than a Gen S TC SS mode) disabled preheat (75W default and punch 5 default), i do not understand a bit of it. i cannot find any settings someone is vaping in TC ss mode besides (wattage from 15-100W and temp from 195-410C<which i consider unsafe) + preheat power or preheat temp simultaneously. 1. is preheat stacking with TC ss316 wattage mode+temperature ? 2. should i enable preheat power/temperature? what are the settings for temp control+preheat pwr or temp control+preheat temp? Thanks.
