mix11898
Full Name
Karankorn Udomtanawat
Location
Thailand
Dovpo Riva DNA 250C
mix11898's Achievements
One thing that keep making me unclear about this is that original Billetbox hard to connect with escribe unless dismantling. And for sure I also want to look at the file setting in it, because so many people keep believing that between original and sxk version, they perform differently.
Yep, that's what I think, by the way I ask about it for just to make sure that I understand it correctly by the way. lol
Someone in my country, "wholeheartedly believe" that apart from the factory setting of Authentic Billetbox's DNA60 and some wiring structure inside the devices that are different, there are 2 versions of DNA60 chip including 1. the better grade of DNA60 for Authentic Billetbox 2. the cheap grade of DNA60 for SXK version. By the way, in my point of view I think that DNA chips have the standard, so I think that all DNA60 should be the same. Is it true that there might be various grade of DNA Chip?
Wow, all of the stuffs you guys explain to me are very interesting (though it might take me sometimes to read, learn and try to understand lol) Maybe, if I have the mod in my hand right now it might be easier, because the only problem now is that I don't have the mod in my hand right now( will try it again maybe on Tuesday maybe. Anyway, thanks a lot Wayneo,BillW50,gwyar
So does it means that if I set it it up like this it would get to 420 F instantly once I press the fire button ? Could you please explain me more about the cold ohm setting (value)?. Is it about the atty calibration or any escribe setting? Anyway, thank you your response Wayneo. It's a good and clear answers as always.
First thing to mention is I have searched throughout the forum, but I still not clear in some points about the differences between these 2 features. I know that Boost is for the Watt Mode Only, while the Preheat is for Temp. And to have more clear in detail, in these questions, I will talk about using the stainless steel only as it can use both in wattage and temp control mode. My questions are 1.As Boost and Preheat both have 0-11 levels (soft - hard) (and yes, although preheat contains 1 decimal place), what is the real different If I set up like this - Power Profile = 50 W + 11 Boost Punch - Temp Profile = 50 W + 11 Preheat Punch + 70 Preheat Wattage (I will just leave the temperature here because I just want to know about the beginning of the puff) Will it boost the same? or the real different here is the preheat wattage setting? 2.As there is no Preheat Time Limit like Black & White in the Colour Version. How long does the preheat actually do there work here? 3.I use SS316L Temp Mode with the Squape S (This RDA has 2 Airflow Options DL/MTL) I set the temperature at 420 F, and tried both Airflows: MTL with 20 W 0 Punch, while DL with 45 W 11 Punch. After vaping, the last puff temperature showed me that MTL one Actually reached the 420 F, but with DL one, it never reach 420 F, but only just around 200-300. is there anything wrong with my TFR? or it is just because the less airflow the easier the coil get to the temperature? 4.Can we actually use Replay in Watt Modes?
Okay that's my bad 😂 ,so sorry that I overlook the sentences. (My gosh, I'm so embarrassed) For the questions, of course, yes I have just bought secondhand HCigar VT Inbox DNA75. It should be arrived tomorrow.
Of course, it's DNA250c, it is not black and white.
Okay thanks a lot Wayneo. ☺️ I'll try it again when I can. I do own the colour screen. it's Dovpo Riva 250c as I mentioned.
Thanks for the replying Wayneo It's 24.24 F as you can see in the screenshot. It is the result I got after the case analyzing What I meant for 84F is that when I start the case analyzer, I have to put in the room temperature right? So it is usually around 28-32 celsius in Thailand. That's why I have to put 84F when I started the case analyzer.
I have tried to run the case analyzer, and the result is below as you can see below. The thing is when I click to upload it to Dovpo Riva DNA250c There were the alert popped up saying "Case Static Temperature Rise is very high, and may be wrong. To change Thermal settings such as Case Static Temperature Rise, go to the Mod Tab. Program as is?" For more information, just to be more clear on the factor, I have set the Fahrenheit to around 84°F as I live in Thailand, the country where the normal temperature is hotter than Europe. 1.Is there anything wrong with my case analyzing? Anyway, I also have other 2 questions about the escribe and TC. 2. Do case analyzing and battery analyzing effect that much on the accuracy of the temperature control? 3. Also in the theme section what is the different between "Coil cold Ohms" and "Coil cold Ohms at 70°F? Edited: My bad i put this post in the wrong forum, I have to apologise to you guys Admins.
