IcyFridge
Everything posted by IcyFridge
  1. I too, would like this profile. I have an internal 21700 (non-removable) P45B in a custom made mod. The battery will only charge up to 4.14V (98%). Trying to get it to go up to 4.2V.
  2. I am a MTL guy and once my Bi2hop comes in I’ll compare battery life with my Billet Box. I also have an old Joyetech Evic primo with arctic fox I can check as well.
  3. My Pixel with the internal battery seems to be fine in that regard. I think this applies to VC products that use an external cell. haven’t tested my parsons but I’m a MTL guy. I’ll try to compare with my Billet Box.
  4. Seeing this on two separate mods leads me to believe it's not the mod, but the chipset itself. So there's no way in eScribe to change the cutoff?
  5. We have someone in our Discord that received a Parsons SBS in an early order, and they are also reporting poor battery life with the DNA80c. I should have mine waiting in my mailbox today, but my RTA is not due to arrive for some more time. This leads me to think it's an issue with the DNA80c itself and Evolv may need to look into a firmware update for this ASAP.
  6. Can you use the profile for two batteries for a mod that uses one? I have a single p26a in my Wicket and the battery pack readout shows 3.8V but on the charger, it says 4.0V.
  7. Version 1.0.0
    587 downloads
    Took the original Gauges theme from SirTimmyTimbit and made everything as green as possible to match with my ultem mods/tanks.
  8. Version 1.0.0
    604 downloads
    Took the original Gauges theme from SirTimmyTimbit and made everything as amber as possible to match with my ultem mods/tanks.
  9. Is there a way to pull the font from a theme? I love the font on the Vapedroid theme, but can't get the font into my own custom theme.
  10. Version 1.0.0
    218 downloads
    Took @ScaryMonkeyMan Vapeboy 3000 theme and made everything red to work better on red mods. If things are hard to see, swapping out the red background for a plain black one works wonders.
  11. Version 1.0.0
    289 downloads
    Using @Gavnaf Arctic Fox theme, I changed things around to work better on a red colored mod. The only things I changed were the colors on the lock screen and main screen.
  12. Mine is pretty much the same. I did a factory reset and still no go. I'm just going to wait on Sir to get back to me.
  13. That theme works just fine. Went back to Gauges after and battery meter is still missing. Tried a few others and they work fine. Just that any theme that has that big battery icon on the screen doesn't work. Odd...
  14. I can do this tomorrow at work. What's this theme though?
  15. I did that right before taking the picture of my mod in the post above (tried reinstalling it several times with a few defaulting now and then, pulling the battery out overnight, both US and INT firmware) I have the INT firmware that was recommended by Sir.
  16. That's not it. It does it all the time regardless if usb is connected or not. I'm stumped by this. I just downloaded the theme on day one and it worked 100%. On day two, any theme that has an animated battery meter like that doesn't work at all. I guess I'm stuck with Vapeboy 3000 as that's working just fine for me.
  17. Here's what I am seeing.
  18. How do you do a hard reboot? I've done battery pulls. And the thing was, when I started playing around with it the themes worked just fine. I had Gauges as my first theme and it was perfect. Just a little too dark for my screen so I went to Vapeboy 3000 and some others. Decided I wanted to try the Gauges again and battery animation/icon was not there. I'm on 1.1 33.2 as well. Whatever the latest version is.
  19. I was playing around with some themes for my new Mono SQ, and now any theme that has a live battery meter on the lock screen won't show the battery at all. Example is Gauges by SitTimmyTimbit. All I will see is the amperage, time, and battery percentage on the screen. I won't see the battery image at all. Same goes for Big Font Clear. Tried resetting my device to default (both US and INT) versions with no change. Using eScribe SP19. I even tried to roll back to an older version of the theme from my backups and same thing. Any ideas?
  20. Thanks.
  21. Yes. I have it set to 5 clicks for lock/unlock. I speak of power on. When I power it on, it's unlocked.
  22. Thank you for this information. I've already modified the screen timings as I hate the screen being on too long. I know there's a way to change the number of clicks to lock/unlock. My biggest issue is when the device wakes from sleep, it only takes one button press. I'd rather it take 5 presses to wake from sleep/power on (not unlock).
  23. Hello all. I'm new to the DNA world and got a VT75 Nano in near mint condition with buttery smooth threads. I love the device except for two things... 1. Is there a way to change the timer for the device going into sleep? 2. Is there a way to make clicking power 5 times required to power on (not unlock) the device instead of one click? The reason for this is that I usually carry my mods in my backpack. If the VT75 goes to sleep in my backpack, it takes only one touch of the power button to turn on. I don't want this to happen inside my bag. I'd love to be able to let it go to sleep in something like 15 minutes and then require 5 clicks to turn it on.
