RoSeTTe
Everything posted by RoSeTTe
  1. Hallo und danke für den Hinweis, ich werde mich die Tage darum kümmern und das überarbeiten. Meinungen und konstruktive Kritik sind immer wichtig und gut!
  2. Version 1.1.5
    642 downloads
    Pennywise, Wooden, Glass, Cloth, Escape from Tarkov Editons available under downloads. More will follow! Suggestions or wishes are gladly considered Pennywise, Wooden, Glass, Cloth, Escape from Tarkov Editonen verfügbar unter Downloads. Weitere folgen! Anregungen oder Wünsche werden gerne berücksichtigt #Edit by NZ aka RoSeTTe Thanks to everyone whose graphics I used or edited. Known Dude from the German DNA Crew: Lukas E. Special thanks to JMat for the great extension of the standard theme which was used as a base. A special thanks also goes to George Lucas the creator of Star Wars for this outstandingly legendary film series and the hole House of Vape Crew. For Patches and Minor update descriptions scroll down. Für Patches und Beschreibungen kleinerer Updates nach unten scrollen. -------------------------------------------------------------------------------- Main screen "Firing" now red when firing as well as all menu or status bars. On main screen when not in active Replay saved puff you can select the ohm reading to shortcut you to the Coil Info screen. Settings changed to Menu for new menu / settings platform Most "Back" buttons removed and scroll up of down off the screen to go to the previous screen. Watts now adjustable in 1 watt increments instead of .1. Temp adjustable in 5 degree increments. New menu platform dived into Profile, Puff Info, Coil Info and Settings on main menu. New coil install screen now has cold ohm temp for new coil and old coil resistance and temp when deciding on new coil or keeping old settings. Profile Menu has added cold ohm temp with current ohm reading and coil material setting added. Also added is the availability to have advanced preheat settings with the Preheat+ toggle when temp control is active. Puff Info screen enhanced with chart and ability to change wattage and or temp for dialing in a perfect puff. Also the addition of several live readings of the last puff. Live ohms, room temp,average power, puff duration, puff volts, puff amps, and average puff temp, and max puff temp when in temp control. When a non-temp sensing coil is installed gives you current battery % instead of temp. Recording Screen with new additions to be able to monitor with every puff. New Coil Info screen added with time, battery %, current profile, coil material, cold ohms, live ohms, coild temp, ability to remeasure resistenace, and ability to lock ohms. New settings menu with System, Display, Device, and About. System gives you date, time, 12 / 24 hr, F or C temp, max puff time and serial number. New Display menu has brightness adjustment, always on, stealth level, auto lock, auto lock time out, and # of clicks to lock, and ability to set unluck device sequence. Device screen now had power bank settings, and battery voltages for up to 4 batteries. About Menu with Lifetime puff count, Theme revision, current firmware, current revision, edition, current puff count, puff count total energy, and reset to take you to a rest statistics screen. Thanks to everyone on the Evolv forum for ideas and themes to give me inspiration for this theme.
