Klapsides
Everything posted by Klapsides
  1. Wooden DNA [1.2]Changelog: -Added Board Temperature display on lockscreen. (with color warnings)-Added charging icons on every screen. WoodenDNA.ecigtheme
  2. Couldn't be more grateful for your comment. I will make a 1.2 version including some charging updates/changes. However, I never charge my batteries on the mod. I use external charger. Wish you the best.
  3. Hello and thx for your time commenting. I only wanted to say, you cannot shoot from lockscreen so you wont be needing the board temp. Except from safety, the rest of lockscreen is for "aesthetic" purposes. If you notice, while shooting on main screen the whole screen changes where you can see the recorded temp. of the coil. For either MTL or DTL I use https://www.steam-engine.org/wirewiz which gives me a "desired" puff temperature according to my coil build. I fire some test puffs on a variable temp. material profile using given temperature and gradually increasing the watts by monitoring each puff in the diagram. When I reach that temperature I get the best possible puff.
  4. Wooden DNA [1.1] Changelog: -Time & Date display fine on lockscreen on both user pref. (24h/12h) -Added icon at Puff Info menu. Uploading and my Settings file. WoodenDNA.ecigtheme WoodenSettings.ecig
  5. Version 1.3
    210 downloads
    Wooden DNA [ver. 1.0] This theme/OS was created in EVOLV EScribe® [Version2.0 SP19] and EVOLV EScribe® [Version2.0 SP19] Theme Designer. Tested on DNA250c® using the Lost Vape Paranormal® mod. Unlock sequence (PIN) is Down - Middle(Select) - Up. You need to set date in 24h form in order to display properly on Lockscreen. No errors or malfunctions reported. WoodenDNA.ecigtheme WoodenSettings.ecig
  6. Wooden DNA [ver. 1.0] This theme/OS was created in EVOLV EScribe® [Version2.0 SP19] and EVOLV EScribe® [Version2.0 SP19] Theme Designer. Tested on DNA250c® using the Lost Vape Paranormal® mod. Unlock sequence (PIN) is Down - Middle(Select) - Up. You need to set date in 24h form in order to display properly on Lockscreen. No errors or malfunctions reported. WoodenDNA.ecigtheme
