So you mean you shaved off the actual thin outer finish off of the internal connecter, threads and all? So I imagine you had to remove it from the mod first, then Dremel it with some kind of wire brush end and then reconnecting it to the DNA250? Am I understanding this correctly? If there's a physical modification I can do to fix it that would be great! The 510 connector on mine is aluminum colour but is probably still anodized.
My DNA250 is constantly having temp protect issues and it seems to be a common problem with this model board. So, as a last resort, I am considering trying to swap the board for a DNA75 board and then rewiring the battery terminals from series to parallel. Has anyone else out there tried this mod?
I also am having this problem. From what I've seen read, It's a common problem with this model and I have yet to see any forums where anyone has properly resolved this issue. I am considering buying a DNA75 board and putting it in mine, and then rewiring the battery terminals from series to parallel. I wonder if anyone else has has tried it.
