Renegade-86
Renegade-86's Achievements
Thanks for the reply. It does seem to be a connection issue. I guess I should have stated that I'm using a Wotofo Profile RDA and most likely not a clone as the guy I bought it from is very cautious at making sure he sells genuine products. I've also had quite a few issues with the 510 pin. It seems it's a floating pin, not sure how it compares to other pins, but seems like it needs replacing. Anyone have any photos of this being done? I just don't know what is behind those two top screws. I'll go through the method mentioned in device manager. I had to lock the ohms anyway to even use Ni80 properly. Hopefull it'll work with SS316. It's been too hot here to do much with it though. Sorry for late replay, I find it hard to do anything in the summer and just experienced the heat wave. Will have a look at device manager once the heat dies down. Plus maybe replace the pin sometime for a more long term solution.
I've had trouble getting SS316 mesh to work. When ever I build on the atomiser the mod refuses to accept it in TC mode and goes straight to power mode. I'm using a Profile RDA with JacVapour DNA 75. Even putting in fresh batteries doesn't seem to fix it. I used the same CSV file provided by escribe.
Thanks. I've started to have issues with Ni80 now. Doesn't seem to be working as well. Going to make a new thread.
Can't any wire be used in TC mode? All electroconductive materials have a temperature/resistance coefficient, so they can at least technically. There are also quite a few sites showing TCR for Ni80, but no CSVs to be found for Ni80 mesh. I tried with a SS mesh CSV on this site, but wouln't work. Is there any tutorials on how to set up a CSV? In the end I just decided to have a go myself as I couldn't find anything online. I used the device monitor to note the resistance at various set temperatures and edited the graph accordingly. I'm not sure how this would work as it sounds like using a ruler to check the accuracy of the same ruler. I managed to make the graph, but couldn't get all the temperature points so I had to make it up in parts. It seems to vape alright, but not sure if there's a better way to do it. Is this how it's done or is there a tutorial you can give on doing it properly? I'll attach the CSV. Ni80 100Mesh.csv
Seems to work now I've installed Windows updates. Also have the routine sleep function shutting off. Just about had it with this OS. Anyone have an csv files for Ni80 mesh?
I've tried many times, done SP updates, reinstalled and yet nothing. I oce got a message something about firmware fail. The mod still works, but I'm unable to upload a csv now. I don't knoq what to do. It seems to recognise the mods name, but not conenct at all. Anyway to do a hard reset? I've looked for help, but found nothing. I click the connect to download button, choose the mod that it recognises, but then the program stops responding. Manafged to issue a "hard reboot", but still no connectivity. Using Windows 10 When uploading latest SP came up with error report: <<< See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** A.WMO: Exception of type 'A.WMO' was thrown. at A.DPP.GPP.VY(WPP ) at A.DPP.TI(WPP ) at A.NVF.Q(MMO , Object , Boolean& , Boolean , OTI ) at A.NVF.GVF.Q() at A.NVF.Q(GLY , Object , Boolean , Boolean& , Boolean , OTI ) at A.NVF.Q(Func`1 , Boolean& , Boolean , Boolean , GLY , OTI ) at A.NVF.Q() at A.VSF.<>c.I(Object , EventArgs ) at A.OQA`1.NX() at A.OQA`1.QT() at A.FQA.BQA.I() ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.7.3416.0 built by: NET472REL1LAST_B CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll ---------------------------------------- DEScribe Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/EScribe.exe ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.7.3416.0 built by: NET472REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- DEScribe& Assembly Version: 1.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/EScribe.exe ---------------------------------------- DimensionEngineering.Common.Platform Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Platform.DLL ---------------------------------------- DimensionEngineering.Common.Platform& Assembly Version: 1.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Platform.dll ---------------------------------------- DEScribe.Branding Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.DLL ---------------------------------------- DEScribe.Branding.Evolv Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.Evolv.DLL ---------------------------------------- DimensionEngineering.Common Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.DLL ---------------------------------------- DEScribe.Branding.Evolv& Assembly Version: 1.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.Evolv.dll ---------------------------------------- DEScribe.Branding& Assembly Version: 1.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.dll ---------------------------------------- DimensionEngineering.PluginApi Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.PluginApi.DLL ---------------------------------------- System.Xml.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.7.3362.0 built by: NET472REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- DimensionEngineering.Common& Assembly Version: 1.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.dll ---------------------------------------- DimensionEngineering Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.DLL ---------------------------------------- DimensionEngineering& Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.dll ---------------------------------------- DimensionEngineering.PluginApi& Assembly Version: 1.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.PluginApi.dll ---------------------------------------- DimensionEngineering.Common.Windows Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Windows.DLL ---------------------------------------- DimensionEngineering.Common.Windows& Assembly Version: 1.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Windows.dll ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.7.3324.0 built by: NET472REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- DevExpress.Utils.v18.1 Assembly Version: 18.1.3.0 Win32 Version: 18.1.3.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DevExpress.Utils.v18.1.DLL ---------------------------------------- DevExpress.Data.v18.1 Assembly Version: 18.1.3.0 Win32 Version: 18.1.3.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DevExpress.Data.v18.1.DLL ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.7.3324.0 built by: NET472REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- BouncyCastle Assembly Version: 1.8.1.0 Win32 Version: 1.8.15362.1 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/BouncyCastle.DLL ---------------------------------------- DEScribe.Core Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Core.DLL ---------------------------------------- DEScribe.Core& Assembly Version: 1.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Core.dll ---------------------------------------- DEScribe.UI Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.UI.DLL ---------------------------------------- DEScribe.UI& Assembly Version: 1.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.UI.dll ---------------------------------------- System.Security Assembly Version: 4.0.0.0 Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll ---------------------------------------- SecondLanguage Assembly Version: 1.0.4.0 Win32 Version: 1.0.4.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/SecondLanguage.DLL ---------------------------------------- SecondLanguage& Assembly Version: 1.0.0.0 Win32 Version: 1.0.4.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/SecondLanguage.dll ---------------------------------------- ICSharpCode.SharpZipLib Assembly Version: 0.86.0.518 Win32 Version: 0.86.0.518 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/ICSharpCode.SharpZipLib.DLL ---------------------------------------- EquationParser Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/EquationParser.DLL ---------------------------------------- EquationParser& Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/EquationParser.dll ---------------------------------------- DevExpress.XtraEditors.v18.1 Assembly Version: 18.1.3.0 Win32 Version: 18.1.3.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DevExpress.XtraEditors.v18.1.DLL ---------------------------------------- TrueTypeSharp Assembly Version: 1.0.5.0 Win32 Version: 1.0.5.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/TrueTypeSharp.DLL ---------------------------------------- HidSharp Assembly Version: 2.0.5.0 Win32 Version: 2.0.5.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/HidSharp.DLL ---------------------------------------- HidSharp& Assembly Version: 1.0.0.0 Win32 Version: 2.0.5.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/HidSharp.dll ---------------------------------------- SaberUpload Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/SaberUpload.DLL ---------------------------------------- SaberUpload& Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/SaberUpload.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. >>> Can't find a single link to SP page anywhere.
I'm sorry for resurrecting an old topic, but I think this should be looked at again. Having a puff limit makes a lot of sense. Though to be able to bypass it with a simple 3 button click would defeat the purpose. You could instead allow for a cool down time period that's set by the user. First it could say cut of at 20puffs for 10 minutes and then slowly extend the time so the person can learn to adjust to longer and longer vape breaks. I've been looknig for something like this for my DNA75 and can't find it.
