Version 1.5
104 downloads
OG Author:
www.DJLSBvapes.com
This Theme even having most features of the DNA Board on Screen, was still made as simple and as big characters as it could be...
Not only is a material based theme where you only need to change the material to vape on the main screen but still gives you access to the profiles under the settings menu.**Updated 5/23 to add Session Mode and Session Time settings to the Preheat/Boost/Session Mode screen
Saints'-UPDATES
Lock screen
Shows last puff energy, puff count, and last puff peak temp
Main Screen
is now profile settings. *IMPORTANT* This is where you change your material for the profile selected *IMPORTANT* updates with live puff energy, live atomizer current, and live atomizer temp while firing.
Preheat/Boost/**Session**
**Added session enable and session time setting** Added max puff time selection(only selectable up to mod limit set in Escribe). If you set puff time in Escribe above limit, then change puff time here it will only allow you to select from 1 to (mod limit set in Escribe, default 10s).
Settings screen
added recordings item to short cut to recordings *IMPORTANT* This is where you change your profile *IMPORTANT*
Recordings
Updated colors to corespond to Device Monitor graph colors(as close as I could by eyeballing it)
Recrodings selections
Added missing round robin from several menus
