Hi There
	I am seeing if someone can point me in the right direction. I have a 250c and using MTL tanks, using the standard theme file set up that came with the tank. With a MTL Geekvape Ammit  .9 ohm coil SS it works fine on Wattage , but on temperature control i always getting temp protect warning that appears and cut out, 13 watts at 200 degrees Celsius, moving the temperature down i still get the same warning but without much vape, occasionally check atomizer and check battery alarms appear . Now changed to digiflavour Siren 2  which has more slightly more air flow and temp protect appears every 13  puffs, but still getting the check battery and check atomizer alarms. Could it be that the standard file on the device is too sensitive for MTL coils . Also i have selected new coil on device. Sometimes when i remove the tank and refit, it did not recognize that the tank was removed , as i should have got he message did you fit new coil ,  This has been doing my head in for 12 months. Is there a better CSV file for MTL users in which these warnings do not appear.
