By my understanding, the only reason why you'd be getting 35W instead of the 75W that you've set in replay is because the chip is trying to follow the same temp curve as when you recorded the puff, and it realises that to not exceed the set temp curve, it needs to provide 35W instead of 75W.
	I'm using an RDA so when this happens to me, I just redrip when I notice the vapour production throttling down. Not too sure how you could fix it in a tank. Maybe keep it topped up with juice? Or maybe wait slightly longer between puffs to allow the wicking material enough time to become at least as saturated when you recorded the puff.
	I'm also using the Horizontech Falcon tank with an M3 mesh coil and I just run it in straight wattage mode. Don't really need to fiddle with temp control there (not that I could even if I wanted to, M3 doesn't have a SS coil like Freemax).  I've created a separate profile for the tank and I just switch to it when I'm putting the tank back on, and I get pretty much a consistent vape every single time. Haven't had a dry hit yet. Of course I make sure that the juice level is at the very least enough to be touching the wicking ports on the coil to allow the juice to soak up.
	Hope this helps.
