Wow, thanks for the background info AND for your work on that theme! I can’t wait to try it out this evening. I can also add replay to custom themes in the future due to the background info you gave. You rock coyote!
edit to add - I deleted the not temp sensing detect condition from the temp section, replay is working after that! Thanks again
Hi,
Replay and temp control does work as designed in my case, using the same mesh in a vandyvape mesh rda. My builds usually come out to .24 and drop to .21 after initial use. I find I have to use it briefly enough for it to get hot and remeasure ohms once it cools down for it to be accurate. I usually do this twice for each new coil.
