ParaVapor
Everything posted by ParaVapor
  1. ParaVapor
    RDA
    Sorry this isn't exactly about dna's, but, I've been having a problem with my Drop RDA on my Paranormal 250c. When I put a coil in, and tighten the grubs, the legs always seem to push to the side, and wedge in the corner, which ends up with a bad connection, which puts the mod into temp protect. Any suggestions on how to keep the legs centered, before I start looking for clamp style RDAs?
  2. Can anyone help me with a CSV file for Hohm Life batteries? Would greatly be appreciated.
  3. Thanks guys. I figured it out. I apparently didn't change the tcr setting on escribe. It was at the default .006. I thought I did, but apparently only on my other profiles. I set it to .00092, and getting really good flavor now.
  4. Can anyone give me a guideline for temp control. Like how high or low do you go above your normal watts and temp for your preheat?
  5. Can anyone help me out. I can't seem to get decent flavor out of my Drop RDA on my Paranormal 250c. My Mesh Pro gives me amazing flavor though. I am building with SS316L, quad core fused Claptons, 30-40 gauge, ribbon, micro coils, at about .14 ohms. Any estimates on watts, temp, preheat watts and temp, and TCR values would be appreciated
  6. Thank you!!!
  7. Thanks. I think I think I figured out that I never added the custom 316l profile. I'm about to do that, and see if that works. Thanks for all your help. The setting guidelines have helped a lot with my Mesh Pro, but still can't get my Drop dialed in. Hopefully the custom profile will help.
  8. Where do I find the setting to adjust the TCR value on Escribe, or on my mod. Lost Vape Paranormal 250c.
  9. I tried your settings, was a little too hot for my build, but it was better. I lowered everything a few watts and degrees, and it's performing much better. does your mod say .042 ohms? And may I ask what theme you are using. I really like that!
  10. I have it built to .12 ohms, and right now, running 40 watts at 475, with a 525 preheat at 125 watt preheat, with punch at 3 or 4. I'm just getting dry, muted flavor now, when I was running it at like 30-35 watts before, at about 370-390.
  11. I just started having problems with my 250c in SS profile. It works fine with my Mesh Pro RDA, but as soon as I put my Drop on it with quad core fused clapton coils, it won't fire above 25 watts or so, according to device monitor. It did work before, then I bought my mesh rda, and been using that for a few weeks, then went back to the Drop, and it all of a sudden isn't working.
