Pop7335
Pop7335's Achievements
  1. That was it. Now it's working like the Vbox/XP combo! Only issue with sp13 is - now it won't see the USB port. Hmm. $usb-devices T: Bus=06 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 39 Spd=12 MxCh= 0 D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=268b ProdID=0405 Rev=01.01 S: Manufacturer=Dimension Engineering S: Product=Evolv DNA 200 USB S: SerialNumber=ROATWXMAFORP C: #Ifs= 3 Cfg#= 1 Atr=80 MxPwr=500mA I: If#= 0 Alt= 0 #EPs= 2 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid I: If#= 1 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=01 Driver=cdc_acm I: If#= 2 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm /etc/udev/rules.d/$ cat 60-dimension_engineering.rules KERNEL=="hidraw*", SUBSYSTEM=="hidraw", ATTRS{idVendor}=="268b", MODE="0660", GROUP="plugdev", TAG+="uaccess", TAG+="udev-acl" KERNEL=="ttyACM*", SUBSYSTEM=="tty", ATTRS{idVendor}=="268b", TAG+="uaccess", TAG+="udev-acl" $ groups <me> adm disk dialout cdrom sudo dip plugdev lpadmin sambashare vboxusers Well, I can see the USB - but the application can't. If anyone knows why, this is a great time to enlighten me. ============== I just got a new/used Rose V3, (even the seller was not sure if this was an authentic or clone), and it absolutely works RIght on the vt133 from the get-go. In TC SS316L mode.: 450F, 0.31Ω, 36w, SS-316L profile - with a sillyassed attempt at Tiger Wire using 26awg SS and .7mm Kanth ribbon. This is the first time TC has acted like TC at all - the DNA hated my Aromamizer v1 and the Griffin-25 with round or twisted SS316, or even clapton SS316. I had even tried the Griff25 with the single-coil insert. Many thanks folks, keep up the linux work! Looking forward to the solution to the USB/access issue Addendum: So, I twiddled around and the USB cable/port are playing lil'bitch - I had to hold it a bit cockeyed, but what I went off and did was: Tried it from the toolbar - no joy. Tried it as "sudo ~/.local/opt/evolv/escribe-suite/launch-escribe-suite" - that worked Just Right. exited and tried again as myself - and that too decide to work (monitor was so pretty ;-) Right now, the only change is: $ cat /etc/udev/rules.d/*.rules KERNEL=="hidraw*", SUBSYSTEM=="hidraw", MODE="0664", GROUP="plugdev" #KERNEL=="hidraw*", SUBSYSTEM=="hidraw", ATTRS{idVendor}=="268b", MODE="0660", GROUP="plugdev", TAG+="uaccess", TAG+="udev-acl" #KERNEL=="ttyACM*", SUBSYSTEM=="tty", ATTRS{idVendor}=="268b", TAG+="uaccess", TAG+="udev-acl" I restarted, and twiddled that USB, but I cannot figure out why running sudo FIRST made a difference, but it did - not messing with THAT again ;-)
  2. I can DL from the vt133, twiddle a few settings, icons, upload.. I can device-monitor, but it seems a little wonky. Nothing related to the [MOD] or [RESEARCHER] tabs works at all. Nada. Zip. I managed to get Virtual Box and some god-knows-the-source WinXP and win7 to work with the Vt133's, USB, escribe and Firefox. (and win7 is like 2-3x slower than XP). In both cases, those VM's can do everything as folks expect with Escribe. (I have not managed to set up a shared directory for the VM, and don't much care anymore). I can state that "Temperature (std)" SCREEN (on the vt133) lists nothing under a "POWER" profile with 'WATTS' as the material on the vt133. I have no idea if that is normal, but it's a fact. Indeed, so far I can safely say: I see no use at all for TC mode - I can't vape anything under them.. Plenty of vapor, just completely.. "meh". OTOH, I find I can enjoy the griff25 and v1 Aromamizer under WATTS. Yes. The Linux beta needs more work. Sort of surprising, since MONO is .NET for other platforms'. Even flyover help and proper feedback to clicking the file (load?) and disc (save?) icons - and many menu options - are just.. No effect or no VISIBLE effect.
  3. Yes. I rather expected that - that was after selecting Advanced, Researcher, etc... Note also, the "About" option doesn't tell what version the install is. The package I have installed is: SetupEScribe2_SP12_INTL.run
  4. UM, I followed the centered, justified text: neither advanced or research or other "works".. All that is visibile is that text. $ version No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 16.04.4 LTS Release: 16.04 Codename: xenial See the attachment:
  5. Well, I installed last week - almost zero issues on ubuntu. Today I got my two vt133's - HUZZAH! I even managed to configure one of them.. Mostly. I am not seeing anything on the MOD tab at all, not even after Advanced and whatnot. I wanted to verify the dual 18650 config; insure it was dealing with 25R's and VTC5a's. No can do. Am I missing something?
