drmaz2000
drmaz2000 last won the day on September 2 2018
drmaz2000 had the most liked content!
drmaz2000's Achievements
  1. yes , it gives the same result. But .. i tried to loose somehow the center pin of the RDA and it worked good. It seems like you said, the 510 connection is more down and i don't know why !! should i disassemble the mod itself and manipulate the 510 connector form inside ?
  2. Hello .. My Boxer DNA250c showing me ( check atomizer ) when pressing the Fire bottom. The RDA's coil is perfect and works on my other mod !! What's the problem and how can i solve it ? Thank you ..
  3. @iambyrdman .. Thank you Bro ..
  4. Hello .. I've made this parallel coil ( Ni80 + SS 316 ) but replay mode couldn't detect it .. is there any setting should be adjusted on Escribe ?
  5. @retird now it's SS316
  6. @retird Nothing at all , just like the pic i showed it to you now
  7. It's only showing this now ..
  8. it was working for some time at first when i got the mod but then after i changed some theme settings it stopped working .. that's why i did restore defaults settings hope it would work again !!
  9. Thanks Bro .. as u said it was set for 4 cells .. But still there no active Replay mode !!
  10. I've a Paranormal DNA 250c which was doing good and then i lost the Replay mode , and when i went for restore defaults from escribe it keeps telling me " check battery " . what happened and how can this be fixed ?!!!!!
