                Posts25
Everything posted by Fabian9988
	Well after work today I went ahead and took the mod apart and took all the 510 wires off. Removed all the solder, fluxed all the areas and used some new strips of wire and re-soldered all the 510 connections. So far so good. Coming in at 0.004 ohm mod resistance and no more ohms jumping all over when I press the fire button. Must have been a dirty, bad solder point or bad wire.
	Yes I'm using that small washer looking thing with the arm pad thing that sticks out and goes around the bottom of the 510 and the locking nut holds it and the 510 in place
	Why do all my other DNA250 mods only jump up and down by 0.001 ohms when using the same RDA and build in the RAW ohms? I feel like since its a 3D printed box that the ground is just not as solid as the metal boxes. Even when I vape on it it jumps from 0.20 ohms, 0.21, 0.22, 0.23 and 0.24 everytime I push the fire button. While my other 2 mods stay right at 0.20 ohms. I don't vape in TC ever and I only use kanthal a1 wire. So it should not be jumping like say SS wire.
	Yes I was using AA to get the mod resistance. Using the same RDA and same 0.20 ohm build on 2 of my other DNA250 devices they were 0.004 and 0.006 and while in AA with the RDA attached the RAW ohms live field would stay within 0.001 up or down. Now with the mod I am having issues with using the same RDA as before and same 0.20 ohm build it was showing the 0.20 ohm in the cold coil ohms, but in the RAW ohms live it would range from 0.386 - 0.405. It is a VT V2 510 with 14G wire running to the bottom of the 510 and to the ground plate. All connections are on snug and arent broken
	I have a 3D printed mod that has an unusually high mod resistance and climbs in AA. Never seen this before all my other mods stay within 0.001 up and down. This one will climb 0.10-0.20 and is very unstable. I have cleaned all of the 510's and all of the wiring is snug and not broken. All tests were done with the same RDA and build.
	I have never seen this mod. I've searched for pics but cant seem to find any
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Nice I'll have t look around on the FB groups and see if any used ones pop up.
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Wow. Do they still sell Hobo X AI mods? I've herd a few times about that mod being as close to perfect as you can get in terms of the resistance
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Yeah I did a known resistance build of 0.7 and with the 0.003 the Rebel is right where it needs to be.
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware When I'm in atomizer analyzer should the raw ohms be going up and down by 0.001 with the atty on all the way? It does not constantly move, it will stay on a reading for a bit but sometimes jumps 0.001 then goes back to the number it seems to stay on most of the time. It looks like the mod resistance is actually 0.003
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Oh so the copper 510 short does not work anymore? Should I cancel the order?
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Ok so I changed the Rebel back to 0 and figured out how to save the ecig files. So I will upload them here. Let me know what you think thanks! Everything is back to how I got them new except the brightness and fade setting stuff. VSDNA250.ecig RebelDNA167.ecig
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Yea hopefully once I get the 510 copper short I will be able to see that the VS and the Rebel are. Cause right now they are 0.03ohms off. Which seems like a fairly big gap when all we're talking about for internal resistance is 0.001's
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Ok I'll set it back to 0 in escribe and when the copper 510 tool gets here see what it comes up with. Obviously the 0.03 difference between the 2 doesn't bother me. I just was confused as to why the same board would show different results. Now that I've learned about the whole internal mod resistance and setting it I can see why they are off. I was just worried my new Rebel may have had an issue. I've already learned a good amount of info here. Thanks everyone
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Yes it looks like the black on there.
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware I have 3 mods and they all read off from the VaporShark. Reload RTA, Goon V1.5 and Cosmonaut RDA. All good quality atomizers. Idk what 510 is on the Rebel but it seems they out a black plasticish type thing over it
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Idk how to do that lol. Sorry
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Yeah I ordered one of the tools last night. So once it's get here I'll be able to do the proper test. I just figured my VaporShark DNA250 is showing true ohms since they actually did the resistance test to get the 0.007 that shows in eScribe. Where as the Rebel showed 0
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware So in order for my Rebel mod to read the same as the VaporShark that was tested correctly the Rebel needs to be at 0.019 ohm mod resistance. Is that normal or a high number?
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Ok thanks for all the help guys!
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware What is the case analyze ?
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Ok I guess I'll have to go grab some TC wire from a local shop. I'll only be doing this calibration on the Rebel mod since it shows 0 and was not done to it.
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware Thanks I'll give this a try tomorrow. I don't have to use TC only wore right? Kanthal will work also
	  DNA250's reading different ohmsFabian9988 replied to Fabian9988's topic in EScribe, Software and Firmware VaporShark is 0.007 ohms Rebel is 0
	Hey I'm new to the forum and fairly new to DNA mods. Looking for some help with a issue I'm having. My RDA reads 0.13ohms on my VaporShark DNA250 with 3S Lipo Pack. But when I put it on my Rebel DNA250/167 it reads 0.16ohms this mod uses 2 18650's. I tried to be as detailed as possible for the best answer. Is this an issue that I can fix? Or is it not a big deal and ignore it? Thank you.
