sykesy13
Everything posted by sykesy13
  1. That's fantastic thanks very much for going to the trouble to help me with this issue and I'll get it uploaded now. Once again massive thanks Ian
  2. Hi JT Thanks so much for your reply and assistance with this issue, i have temporarily set the battery setting to 24.25 so it matches the reading on the screen which is much better than it was. If you do manage to track down the csv file then that would be fantastic. Thanks again Ian
  3. Hi there Thanks for the reply and if you could possibly retrieve your results that would be fantastic as I am not very keen on running the battery analysis. I would be eternally grateful.. Ian
  4. Hi there First off I am using Sony VTC5A that are about 6 months old but have only had about a dozen cycles and none of them did i let them fall below 50%. Secondly the battery indicator does not change after sitting (even overnight). What i find strange is that this never happened before with charging the batteries internally and only happened when i removed them to charge. Lastly they are 100% genuine and all grade A cells bought from Fogstar which is a major battery supplier in the UK. I think i will just get 3 brand new cells and see if that improves the situation but firstly i will let them discharge and see if it improves by charging them internally again. Thank you for your reply
  5. I have just charged my batteries externally for my Lost Vape Triade. I then put them back in the mod and they were reading not fully charged?. I then looked at the device monitor and found that the batteries were showing 85% but all at 4.20v?? I then checked the battery settings and found them all okay with it being set for 3 cells and 27.5kwh and the cut off at 2.8v. I have no clue what is going on with this. Has anyone got any ideas??. Thank you in advance
  6. I have just charged my 3 batteries externally and when I put them back in to my lost vape triade the battery indicator on the mod showed that the batteries were not fully charged?? I checked the device monitor and it showed my three cells all at 4.20v but the total being 85%??. I then checked the battery settings and it was all okay ie : 3 cells and cut off at 2.8v with the total wh at 27.5kwh. I have 3 x VTC5a batteries installed but I am totally baffled with this. Any ideas??
  7. Yeah I have watched it when it came out. The replay does protect you from dry hits and is designed to work with coils that are made from the TC metals ie: SS, Ni200 and Titanium or any combination of the above with kanthal or Ni80 etc. Cheers
  8. Hi, because they give you the option to use the replay in TC should you choose to, although it is much easier to use in wattage (power) mode 🤔
  9. Yeah found it and have updated my 75c no problems ,also new theme. Just curious to see if the 75c works on replay the same as my 250c. Thanks again
  10. Has the new replay feature been released for the 75c yet?.I have heard people talking about the function on their 75c. I have just re installed the latest Escribe and when i connect my 75c there is no mention of an update!!.Am i missing something? Thank you
  11. Hi there Thanks for the information but I just clicked on help and went to the backup downloads and installed the file with a previous download/upload before I hit the reset. Cheers
  12. Hi there They must be the settings for the paranormal as i don't think that Evolve have a default value for the thermal properties as they have no idea what mod the board is going to be installed into when they sell them.
  13. No i accidentally clicked on the reset to default meaning to click the device information above it and it reset it to a 4 battery device and the replay was not working and everything was f@#ked up. So I had to set it all up again lol
  14. Hi James I take it that it is the bottom one that shows the main screen
  15. Thanks so much for all your help and replies in this matter
  16. Hi James Thanks so much for your time and assistance in this matter, at last someone who says more than just its in the theme designer..
  17. Thanks for the reply and assistance Nick
  18. OK thanks so much for your assistance I've been told several values and I will be going with yours. Thanks again Ian Sykes
  19. You mean 0.04 and not 0.004
  20. Thanks for the reply, I think that this is the standard that lost vape sets it up at.. Cheers
  21. Thanks for the reply and but don't you mean 0.04? and not 0.004
  22. Hi there What is your mods internal resistance set at when it came to you. Thanks in advance
  23. Can anyone tell me what the internal resistance is for the lost vape paranormal dna 250c is supposed to be? Mine came with it set at 0.04 which seems a bit higher than usual. My paranormal dna 75c is only 0.014. I don't want it to be way out and playing havoc with my replay and temperature control. Thank you in advance to anyone who can help.
  24. Hi there I have been looking for it as well and couldn't find it anywhere either. I do know that it is buried deep in the theme designer but can't find it!!!!. Also what did you set your internal resistance at?. Mine came with it set at 0.04 which seems to high to me. Thank you
  25. Thanks for your reply, much appreciated 🙄
