Popeye
Popeye's Achievements
  1. Hi all, So i got a Vaporshark DNA 200 a few days ago from a friend. Up until yesterday the fast charging was working but today it suddenly stopped. Connected to my laptop it charges at 0.5A (as expected) but on my 2A wall charger it only charges at 0.6A maximum. What can i do to get the fast charging back because without it the mod is useless pretty much
  2. Hi all, I know the Vaporshark has the capability to charge @ 2A and maximum input voltage is 16V. Does this mean the DNA 200 board can cope with the varying input from a car alternator? Max volts should be 14.5V ish. My charger is fused @5A Thanks
  3. Got any photos? Im not familiar with the dx
  4. Thanks guys. Just wondered because i dont send stuff internationally and never really ordered much that came directly from overseas
  5. Ok great i triple checked the address so i know its gone to the right place. Sent from the UK so well aware it could take a while to get there
  6. Ok thanks.
  7. Hi all. To those of you who have sent devices off for RMA how long was it before you got an email response, or device returned?
  8. My vtbox 200 is doing something similar. When i charge it, it eventually displays 100% at 11.9V pack voltage, if i do a soft reset it drops down to 70% then charges normally. After this it charges to 4.2V per cell. Seems to only happen if i drain the battery below 11.1V
  9. Dont these use fullymax cells? Id be taking the device back to the seller
  10. One thing i think would be good would be for the mod to auto off when the battery reaches 100% after charging. Currently while plugged in my screen stays active the entire time, where i would like it to reach 12.6V then turn itself off.
  11. How did you do that without damaging the cells or the wires?
  12. Would it be possible to have the option of switching temperature readings to celcius? I know conversions and calculators are out there, some of us are just used to using Celsius. Also, Would it be possible to change the display screen items based on a selected profile? For example, my usual settings are based around the battery in normal useage, with the percentage, pack voltage and puff counter being used, but if i want to use a temp control build it would be great to be able to switch to a different profile and have the temp control setting on display.
  13. Just in case the OP is subscribed to this thread, did you ever get to the bottom of this? I had an issue where the battery sagged so much at 50w that it wouldnt fire from a full charge. Changed the battery and it works well now
  14. At 7.8v i wouldnt even risk trying to charge it. At 2.6v per cell there is pretty much no doubt that the cells will have some damage. Your vendor needs to replace the mod.
  15. i can get just under a day vaping at 75w but im a heavy user, so could say 250 puffs to a charge. Before i was lucky to get 130.
