I'm so tired of my Hana, wish that trade in for a reference unit was still an option! Now when I press my fire button the screen turns off. It's strange how it does it - the info on the screen freezes, and the backlight shuts off. Randomly I have to tap the button again for it to turn back on. I have another screen but last time after taking it apart I don't know how I would re-position the screen?
Did you change your mod resistance yet? And you can update the firmware using the link posted above - it's the same board, you don't need software from wismec or hcigar to update it.I find thtlat SS usually needs to be set higher then, say, Ni200. And when you consider the evic is actually getting hotter than you have it set to, the temp is always gonna need to be adjusted on a different mod. (So I gather, I don't own an evic)
Its really hard to see the actual crack. I've seen plenty of these type of screens broke with the spreading black. I got it from vaportekusa so I guess I can ask them....I'm super bummed about it. And my Hana V200 is broken (again.) I just got it back and now the screen turns off when firing. I double checked the settings, definitely not set to dim out or anything on firing...
So, my rolo just took its first tumble to the floor. Picked it up and a little scratched but fine. Then I notice the screen isn't showing properly. On closer inspection there's a tiny crack in the.corner of the screen. Not sure exactly where I would send it for service. Can it just be mailed to evolv and a replacement screen be put on it? Slight pressure and everything lights up fine. Still works fine, as well.
