augtism
Everything posted by augtism
  1. I just got the Aspire Cleito. Love it more than the crown so far!
  2. Is it safe to use external battery chargers for lipo dna200? I have the VT200 and using this charger: http://www.amazon.com/Anker-6000mAh-Ultra-Slim-Portable-External/dp/B00CEZJT2E Thanks
  3. Mine fluctuates with Crown SS using wattage mode. When I watch Pbusardo's videos on youtube, if I remember correctly he said in escribe on the Mod tab, under Electrical, in Ohms lock range, change it to 100% instead of 25% and it shouldn't fluctuate anymore. Idk if it's a good idea or not. You should google it or watch his video I now use a custom profile with my Crown in TC with SS. Ever since, my ohms never fluctuate and it's not even locked. My ohms locked range is still the default at 25%
  4. Mine is 8/21/15 is this the latest?
  5. Thats a bummer. You can save everything. In case it happens again go to file, save as
  6. Yeaaah I'm pretty sure chromebooks run on ChromeOS not windows. if anyone finds a way, i'm buying a chromebook real soon lol.
  7. I use this CVS file for the Crown SS http://www.filedropper.com/dna200-ud-ss316ldjaquithv3 The Crown use some "Grade D SS316L" whatever that is!? In addition, I disable the Preheat; 'tip' I'd recommend that you try is to turn-off Preheat using SS, other wire no, but SS .. I'd certainly try it; (1,1,0): Let me know. I also read here about TCR's, on the Crown 0.00097 is what I've used with minor tweaks. SS for 'TC' is a pain, Titanium Grade 1 by far is my preference. [/QUOTE] Wow works flawlessly. Never vaped in TC with ss crown coil until now. Thank you!
  8. Thank you. I am not sure where I had found that but read a post where someone tested it and that's the number that I am using now.[/QUOTE] Awesome Thanks
  9. mine is 0 also. anyone know what it should be?
  10. You got it. I had the batt cell 1, 2 and 3. It was 4.20,4.20, 4.19... after a few minutes the 3rd cell went to 4.20, but then the second cell went to 4.21 then I changed fields to battery charge %, battery charge Wh, Battery pack. results: 100%, 8.99, 12.6v and I haven't loaded the CSV profile yet edit: now the CSV file is loaded. vaping heaven
  11. Ok cool. Now when you say vape it till it's drained, do you mean while it's connected to escribe?
  12. Ok what doing you mean a charge screen of 50%? brightness?
  13. Ok. You think it's a good idea do this before using the device? I haven't used it once. It's almost done charging.
  14. Thanks for converting that so quickly. I presume I just click "Load CSV" then click Upload Settings To Device. Disconnect. Not doing this yet btw
  15. Yea could you convert it, I appreciate it what is the difference between me manually putting in 11Wh in escribe and importing this csv file?
  16. I don't have a resistor or anything to test it. Just my Hcigar, tank, and escribe is all I have
  17. I wish. I don't have anything to test it. I have no resistor. Just my Hcigar, tank and escribe is all I have
  18. so nobody knows what to put for the Wh in Escribe? that's crazy. Mine is set to 9 by default.
  19. Thanks guys. I have it now. It's charging atm. I have not hooked it up to escribe yet. Letting it charge. But my previous Hcigar said 9 in the watt hours and 3.09v was the soft cell cut off and the charging mode was on Maximize Puffs. I left it as it is, because I wasn't sure what to put in the Wh. I checked online a lot. I find mixed opinions. Some say put 14.43 in the Wh, others say it's not actually 1300mah lipo it's a 1000mah lipo, so put 11.1Wh instead of 14.43. So I just kept mine at the default. Battery wasn't terrible at 9Wh. About 7 hours of moderate vaping. I just want to avoid this thing failing again. I should run the battery analyzer
  20. Could never figure out if vt200s should be changed to 14.43wh or 11.1wh in escribe. You happen to know?
  21. Absolutely. I'm open to more dna 200 advice
  22. I asked they are letting me get a new one! It's my second replacement. And It's been well over a month, so that's crazy. These guys have a lifetime customer right here. I can't help but feel bad lol If you ever hear of NiceCloud shop there...awesome people. Picking up my new Hcigar in about an hour. I have to drive at the store furthest away this time haha oh well
  23. Yeah I can't afford that. I asked and he's letting me get a new one!
  24. I think you are right. It's Hcigar. I think it's their batteries, but I speculate. Good news, they are giving me a new Hcigar, because I asked. So happy. Heading over there soon.
  25. First one wouldn't charge anymore. Once it died, it never came on again. They replaced it with a new one. It randomly shut completely off one day. I plugged the charger in. Nothing, but a noise. A weird clickey noise came from the mod. Like a fast heartbeat. The screen didn't come on. I was nervous to even keep it on the charger. After some time on the charger it eventually came to life. It was really warm. Now it gets very warm when it charges. Also gets very warm when I used it. It got my tank very hot also, so I completely stopped using it. It died very fast while idle. Even when I didn't use it, it would die in about 90 minutes.
