Is it safe to use external battery chargers for lipo dna200? I have the VT200 and using this charger:
http://www.amazon.com/Anker-6000mAh-Ultra-Slim-Portable-External/dp/B00CEZJT2E
Thanks
Mine fluctuates with Crown SS using wattage mode. When I watch Pbusardo's videos on youtube, if I remember correctly he said in escribe on the Mod tab, under Electrical, in Ohms lock range, change it to 100% instead of 25% and it shouldn't fluctuate anymore. Idk if it's a good idea or not. You should google it or watch his video I now use a custom profile with my Crown in TC with SS. Ever since, my ohms never fluctuate and it's not even locked. My ohms locked range is still the default at 25%
I use this CVS file for the Crown SS http://www.filedropper.com/dna200-ud-ss316ldjaquithv3 The Crown use some "Grade D SS316L" whatever that is!? In addition, I disable the Preheat; 'tip' I'd recommend that you try is to turn-off Preheat using SS, other wire no, but SS .. I'd certainly try it; (1,1,0): Let me know. I also read here about TCR's, on the Crown 0.00097 is what I've used with minor tweaks. SS for 'TC' is a pain, Titanium Grade 1 by far is my preference. [/QUOTE] Wow works flawlessly. Never vaped in TC with ss crown coil until now. Thank you!
Thank you. I am not sure where I had found that but read a post where someone tested it and that's the number that I am using now.[/QUOTE] Awesome Thanks
You got it. I had the batt cell 1, 2 and 3. It was 4.20,4.20, 4.19... after a few minutes the 3rd cell went to 4.20, but then the second cell went to 4.21 then I changed fields to battery charge %, battery charge Wh, Battery pack. results: 100%, 8.99, 12.6v and I haven't loaded the CSV profile yet edit: now the CSV file is loaded. vaping heaven
