hello,
i have dna200 boards.... i want to make a (DIY) mod with a single 18650 battery but dna200 board cant support single 18650.....is there any way, software upgrade etc or any hardware trick to run dna200 board with single 18650 battery (reduction of power (wattage) is no issue)
regards
You are welcome, just glad you got you mod working again.[/QUOTE] Hello how r u? i have installed the automotive fuse it was working good but suddenly my mod stopped working. i have checked the automotive fuse (which is not blown), OLED, battery (working good with other mod) and the board but i remained unable to understand the problem. Can i send my board for warranty?
I am using a VT200. I have open the my mod and found that lipo pack has become fat. Battery is still charging but i think battery time have been reduced. is it dangerous. what should i do?
When i press power button, the escribe shows variations in the graph but the device does not gives power to atomizer rather a message "check atomizer" displays.
Maybe there is some issue with screen connections but the board is also not giving power to the atomizer.....on pressing the power button "Check Atomizer" is showing on the dim screen.
Suddenly the screen on my dna200 become very dim...... when i press the fire button, the message displays "check atomiser". i have checked and attached it with escribe, there is no issue with battery. I cant understand what is issue. i have attached other atomizers but the same message displayed.....and the screen remained very dim.
I got performed Escribe USB Recovery Charging....it worked and now the voltages of 3 lipo battery cells are above 3 volts, as well as, the voltages are in-line with each other. Because of your expert advice, i have succeeded to make my mod in working position, without sending the same to Evolv for warranty. Thank You Very Much One thing i want to confirm that whether (with this 25 Amp automotive fuse) my mod will work as worked with the on-board fuse. Is it safe? [/QUOTE] Thanks
Maybe the battery is too much low.... is there any other way to charge the battery..... i have a Nitecore single 8650 charger can i charge my lipo pack with it? It is also said that if the battery is too much low it could be dangerous.
