David247
Everything posted by David247
Hi I got a new build and the battery is not charging even though the battery bar says so working fine otherwise. Thanks David
Hi out of interest did the fuse go the first time ? Thanks David
Hi I was driving home form work last night vaping away and she goes dead in the middle of a vape on me not the fuse and the board looks fine no communication with escribe. Its a mod a made myself and was working fine till a few weeks ago till the fuse went changed it and now this .19 ohms at 15 watts kayfun 4 battry showing 11.4v on both sides of the fuse on the volt metier. Regards David
510 ground on 6061-T6 Aluminium box
David247 replied to David247's topic in Installation and Assembly
Hi do I need to ground the 510 to the board if im screwing the board to a 6061-T6 Aluminium box ? Regards David -
Hi I found vaping by charging bought my cell back inline as soon as the other cells reach 4.2v it stopped charging Regards David
This is what I done too Regards David
Hi got a unbalanced cell after changing the fuse it was 3.85 yesterday after a charge up to 3.97 any ideas to get it back ? Thanks David
Not completely dead but not alive either. And doesn't work
David247 replied to vapealone's topic in General Discussion
Hi mine had the same symptoms wired ohm reading and unstable power delivery before I changed the atty then the fuse went which I have changed now hope it's ok now Regards David -
Thanks I manged to replace the fuse not a nice job to do or looks pretty but is back working Regards David
Hi my fuse has blow and was wondering the best way replace it ? Thanks David
I think its fitting the screen in before the board it is a tricky job I used automotive double sided tape, I damaged 1 screen trying to fit it lucky I had a spare from repairing my vaporshark rdna40 and using glue on a $200 mod it a bit of a cheek Regards David Ps I will take a beta unit too lol
Going to have to make one of those Regards David
Got its 1590A Regards David
Hi nice job where did you get that case ? I think I would need to dig out my usb microscope to change the buttons Regards David
Your right thank you basilray
Thanks i will try it Regards David
Is it possible to have the watts adjust once the given temperature is reached to maintain the set temperature instead of having temperature protection screen ? Regards David
If you put page 17 of the data sheet the pic of the board into word and up it 103% print it cut it to size you can use it to mark your holes Regards David
Hi any news when the beta case will go on sale ? Regards David
Hi had to make mine from these http://www.ebay.co.uk/itm/400328192495?_trksid=p2060353.m2749.l2649&var=670413166611&ssPageName=STRK%3AMEBIDX%3AIT I used the m2 but you have to curve them of at the end so they don't touch the parts on the board M1.6 screws 10 mm long and nuts Regards David
Tiny 133watt box mod Regards David
