marcsz
  • Full Name
    Marc
    Pratteln, Switzerland
    Reuleaux DNA200, self made
marcsz's Achievements
  1. Will definitively do that. Actual delivery time for the switches is 8-10 weeks. So it will take some time...
  2. Thank you very much Nick for the information. Looks great! @retird If anybody else now wants to do something like this the information is available for every one in here and not only in my email inbox.
  3. So if customer support is held high there should be a reply. :-D
  4. I expected Evolv to be visiting this forum from time to time and answer questions other users can't answer. Are they really not showing up here?!? Unfortunately not regarding my construction. I don't use the button on the board.
  5. Hi everyone I thought about using a illuminated switch with RGB capabilities. I will then connect the LED's of the switch to the pins on the DNA75 (after removing the existing RGB LED). Before doing so I need some specs regarding the LED. - I need a pin-out of the on-board LED to see which pad is R,G,B and mass. - What is the maximum current which could be drawn? The switch I found needs 20mA on each channel and I don't expect that this much current could actually be drawn (but would be nice tho). - What are the voltage levels provided for each colour? The voltage levels on the switch I found are as follows: Red=1.8V; Green/Blue=2.8V Here is a link to the datasheet of the switch I thought about using: http://spec_sheets.e-switch.com/specs/52-PV6F240SS3R1.pdf Thanks in advance for answering my questions!
