Today, I was charging my Reuleaux on the way home from work and it stopped charging. I was using a 1A good name brand charger and a Samsung USB cable for my phone to charge with that are both good. Anyways, I connected it to my computer and it does not connect to it or show as charging. I rarely use internal charging but when I do, I do it in a pinch. Any help would be appreciated.
I just bought the DNA200 Reuleaux and was wondering what I needed to do in eScribe to get it set up properly. This is my first time messing with a DNA 200 device. So far I am loving this mod and the DNA 200 chip. Hardest hitting chip I have used to date. Going from an X Cube to this has really changed my settings on how I vape.
Alrighty, Thanks for the replies. I am selling off a few things so I can at least get the DNA200. Too bad this thing will definitely be a work in progress. I want it done right and the pre-built boxes I am seeing so far are pretty wonky in the design.
This is an important question that is probably plaguing a lot of people. Should I buy the battery or a case first? Looking at purchasing a 2200mAh battery but haven't decided which one. I want to make sure the case will support the battery which is why I am asking.
I went to ITT Tech and studied Computer and Electronic Engineering. Was not able to get the degree due to some unforeseen life events. I have mostly used what I learned for hobby stuff and PC repair. Currently working a factory in Peru, IN mostly using saws, machine presses and table presses. This was a recent project of mine and as you can see, I would probably make a good fit with my soldering skills. Unfortunately the drive would be 4hr 20mins one way from Indiana unless I relocated . Pay no attention to the leads on the board. Left them long enough in case something did not function properly and they are about to get a trimming.
