sy5tem
    Montreal
    dna 200
sy5tem's Achievements
  1. nice pics kraze6548 what we really need is a bigger battery door i think this mod could be 1cm larger and still be really great!
  2. Well the hcigar is really a 900mah battery ... they sell it as a 1300mah but its a lie. (here is the video part of Pbusardo on youtube saying so : https://www.youtube.com/watch?v=D3vNJRT0uh4&feature=youtu.be&t=1h5m45s ) also user experience here on forums .. and the size of the battery physically .. its imposible its a 1300mah. and for the cell cuttoff you can use 3.09 if you want but as i learned trough RC hobbyist this will shorten battery life considerably ... you will just have to change battery more often
  3. hello heres' a thread about this /topic/66435-topic/?do=findComment&comment=897339 righ in these forums!
  4. like bmclaurin said .. plus if you want a longer battery life..(lipo don't like deep discharge and overcharge ) use the escribe software and set the proper settings first capacity of hcigar is 9.99 wh 3-cell cell soft cutoff put that at 3.7 (you can go down to 3.2 to get more batterie time vaping.. but the lower you go the shorter the batterie life total will be )(check rc forums about lipo cell cutoff) Also if you set charging mode at maximize Recharges cells are not going to be charge over 4.1 wich also increase battery life..... also for hcigar vt200 mod Resistance is 0.0045 ohm have fun!
  5. arent 1000mah 11.1 battery 11.1 wh ?
  6. hey TheRedBaron i did the same steps as you did only i did not go an thinker with the vt200 with a dremel! i wish i could see you job! anyways here are some picture of the turnigy 1300 VS the hcigar 900mah (1300mah advertised ) so people can compare... EDIT: the smalest battery is the hcigar one
  7. i am using a Razer Lycosa on a GA-990XA-UD3 (AMD)(rev. 1.x) USB3: Etron EJ168 USB2: AMD SB950 same freezing problem with keyboard
  8. after buying a bunch of battery to replace my dead oem battery... i found this Specs: Capacity: 1000mAh Voltage: 3S1P / 3 Cell / 11.1V Discharge: 60C Constant / 90C Burst Weight: 96g (including wire, plug & case) Dimensions: 70x34x19mm Balance Plug: JST-XH Discharge Plug: XT60Need to solder a xt30 plug and remove plastic around the cell then it fits, its a 11.1 WH battery and its lasting me all day @ 50Watts (original oem 1300mah is really a 900mah battery) https://www.hobbyking.com/hobbyking/store/__80281__Turnigy_nano_tech_A_SPEC_G2_1000mah_3S_60_90C_Lipo_Pack.html
