cukrus
Everything posted by cukrus
  1. any chance to get dimensions of the actual extension ?
  2. i used ss430 awg24 yesterday and let me tell you- temperature is stable as hell when comparing to SS317L
  3. i have ss430 coming. 24awg. I'll see how it goes.
  4. happens to me as well. Good thing it is SS
  5. same here. don't think it's an issue
  6. I can confirm. 0.6 SS317l is more accurate and jumps less than 0.2
  7. if you have a solid works file i can go and make it out of billed aluminum, same material lavabox is made of. then make a longer grip with 3d printer. what i need is the solidworks file though Or even the dimensions..
  8. but you cant enter 0.00088 ?
  9. Hi do you think you could give me the dimensions of the washer? I'd like to print washer+back cover in one part with a 3d printer
  10. do simple 5 wrap single coil and dont over tighten the screw ffs, it's not kanthal... Before screwing the atty on, do a hard reset. That doesnt work,warranty
  11. how will this perform with 317l ?
  12. can you let me know the dimensions of the battery ?
  13. Becuase a washer would mean the item has a lot of parts now. where as I can make a "click on" back panel that would look the same and would cover the back and accomodate any battery (that is not more than 70mm tall) Just curious, why would you rather have this than just adding the washer?[/QUOTE]
  14. If you would make a 3d model of the "washer" that has a longer back panel integrated into it ( i mean one piece back) i would 3d print it and test it
  15. 70mm x 26mm x 19.8mm is the 950mah turingy battery. seems better, no ?
  16. I just started mine. It'll go for 6 hours or so
  17. leave it for 5 hours and the temp will be the same as room temp or a few degrees higher. on usage i reach around 86f
  18. can you do a picture of this? I still don't understand how to get the correct mod ressitance
  19. i just called volcano to check if they can give me the file for battery settings and said NO. wow...
