speed4mee
speed4mee's Achievements
  1. Don't fire the mod when you are shorten the atomizer!
  2. Try to align the batteries properly
  3. I think to show the current is useless. I switched from Volt to Last Temperature
  4. I think you've made something wrong. You use a Reuleaux that i can see from ECF. Be sure to run the latest EScribe Software and load the latest Firmware according to: http://www.wismec.com/product/reuleaux-dna200/ You can also load the setting file. First you can control the resistance of your atomizer with Atomizer Analyzer. If you change settings don't forget to klick Upload Settings to Device. Another method is to go to Device Monitor to control your Settings. Try it and be Patient, it's worth
  5. Did you checked the balancer ports?
  6. Why did you swap the lipo batt?
  7. I think the 20s puff cutoff is a bit too Long. I would prefer 10s, but i can't change this in EScribe
  8. Gold coating over stainless steel is the worst for the mod resistance. I prefer my brass connector #1818, no issues Are the threads also goldplated?
  9. Which operating system do you use? Can your USB cable provide data transfer?
  10. I've had no problem to install over an existing version under Windows 7
  11. Set Screen -> Charging Brightness to 0%
  12. Is it possible to show a live view from the screen of the display that isn't attached This can be useful for testing a mod without an attached display or with a defective display. My display is dead and so i wish a software screen for the missing display.
  13. Another bug in the 8/5/2015 EScribe Version: Sorry, it's German If i activate debug with 7-click on Evolv Logo then all is ok.
  14. When i push the Get Information Button i see this in Windows 7: It's the 8/4/2015 EScribe Version.
