joseph1203
Everything posted by joseph1203
  1. you can consume all your battery life? or in what battery % appeared check battery on your screen? mine is 35% and then i need to replaced my spare cells also i check on batt analyser my 2 cells are below tbe cut off. is it normal now or theres any issue on my batteries or mod?
  2. when was the battery vheck appeared on you screen in what battery % you can consune all the battery life down to its 5%? if the said cut off reaches
  3. hi do you have a video on how to disasembled the therion 133? procedure and step by step.
  4. do you have curve in awt? kindly share because my spare battery is awt same as to you. is it correct if Mah is 3000?
  5. thanks again sir i'll update you once i test the battery
  6. thank sir. i will wait for the result of the test.
  7. curve is for 3 cell. im using 2 cell. btw thans for the update. but how can i see on mt device monitoring if there's ant abnormalities in my mod or power?
  8. also on your device graph wheres the cell cut off be located?
  9. ok sir i'll let you know if i already done it and i will screenshot it. did you find any issue regarding my screen capture of my device monitoring?
  10. How can i test that power ramp up'? Also can you provide me the csv of lg hg2 curve?
  11. that my battery profile under device monitor. how can i test the one that you've said? Did you look at the cells under load (when firing) in Device Monitor to see if one is hitting the 2.8 V cut-off?
  12. not yet sir im on the office right now. i will tell you later once i got home.
  13. hi sir i already done it. no issue at 510 and contsct however still same pls help sir
  14. thanks sir. i'm a newbie here how can i clean and check if there's any loose?
  15. how can i know if the contacts is good? but if fully charged it seems okay. however when it drops to 50% problem occur
  16. hi sir, please help me with this.
  17. hi guys, thanks for the response. how can i fix this issue? any recommendation/suggestion? i don't know how to dissembled my Therion help me up guys. this was very disappointing
  18. Im therion 133 user my battery are (2 18650's) LG Choco married with battery setting of 22.2 Wh, 2 cell,7.4 voltage. With cell cut off 2.8V Reading: .25 ohms, dual coil. spaced fused clapton, RDTA: Avocado 24 new Queries: #1. Every time my batteries discharge at 50%, my wattage was unstable. It keeps changing and unable to reach my desire wattage (ie. im firing 60W but unable to reach) what will i do? #2. Every time my batteries went to 50% sometimes unable to fire. "Check battery on my screen" is my mod was damaged? my batteries are 2 weeks old Please help guys. Appreciate your swift response. Thank you!
  19. Im therion 133 user my battery are (2 18650's) LG Choco married with battery setting of 22.2 Wh, 2 cell,7.4 voltage. With cell cut off 2.8V Reading: .25 ohms, dual coil. spaced fused clapton, RDTA: Avocado 24 new Queries: #1. Every time my batteries discharge at 50%, my wattage was unstable. It keeps changing and unable to reach my desire wattage (ie. im firing 60W but unable to reach) what will i do? #2. Every time my batteries went to 50% sometimes unable to fire. "Check battery on my screen" is my mod was damaged? my batteries are 2 weeks old Please help guys. Appreciate your swift response. Thank you!
