Juggaloassassin123
Everything posted by Juggaloassassin123
  1. Alright cuz like I said the atty I was using wasn't a stainless steel built atty it had nichrome but for some reason it was reading in TC an saying temp protected and what would cause a atty built with stainless to stay in TC but act like it was kicking out cuz i have a tsunami with ss claptons an I lock resistance and everything with both profiles an one of them always acts like it's kicking out of TC showing the dash lines but still works fine kinda confuses me
  2. What cause a profile to read temp protected on a atty that isn't built with TC wire cuz I'm using a flawless production built with 10 Wrap nichrome and on one of my ss profiles it always reads as temp protected
  3. I'm using the .000915 curve
  4. And I don't think I did but I copied the profile from my first DNA to it an still seems to be acting funky
  5. So at some points the area that displays temp will say for example 400 soon as I fire I get the dash lines showing its kicking out then I go to another profile an it seems the temp fluctuates an I have set the mods resistance to .009 as of now an it's reading my current dual claptons at .18 but seems iffy compared to my other DNA 200s which read them at .15 guess cuz I haven't messed with those mods resistance any an seem to fire in TC fine
  6. I just got a replacement Aria anarchist from Beyond vape an have plugged it into escribe and everything my mod resistance is zero and have tried setting stainless steel profiles but none of the ones I set up seem to be working
  7. So the connections an stuff would be the same?
  8. Question for any of the custom DNA makers have you figured out how set up a DNA 200 to Run lipo and or 18650 sled?
  9. How would that help?
  10. I have a cloud maker White out DNA 200 with the panel kit but most of the screws are stripped on it any idea on how I can get them out?
  11. oh ok and I'm kinda concerned that before I put it back on it wasn't even seeing it as a TC coil set up even though I know it and it works fine on my other DNA
  12. I recently picked up a cloud maker white DNA 200 from a friend of mine an have updated my escribe and uploaded just one stainless steel profile and for a while it worked then it flashed a temp protected warning and when I took the atomizer off the mod and put it back on I said yes it was a new coil and now it's kicking out of TC what have I done wrong ?
  13. It' never stays the same I upload stuff to mod go out for one minute vape it doesn't stay in TC go back an plug it back in and my tcr value for SS changes to .006 both on mod and escribe I have contacted company I'ma send it off soon an either get internal resistance set cuz apparently never was or whatever wrong with mod fixed if it's severe enough new mod coming my way
  14. I just contacted beyond vape I'ma send it in and have them look at her
  15. So what bout the tcr values changing
  16. I've done tried to taking case off but battery is tight
  17. No the .006 is the tcr value of the stainless for some reason no matter how much I set it if I unplug mod go outside vape come back in an plug it back up the tcr value on both mod and just in escribe changes
  18. Seems I have the most recent one
  19. No mine is newest software cuz I have another DNA 200 I use too and it seems to work fine
  20. What do you mean
  21. Even if it's just a matter of minutes
  22. I set it exactly as it says for SS an every time I unplug mod an plug it back in it changes
  23. For the longest time though my stainless was working fine just within the last few days it has stopped working an I can never get the tcr value to stick either
  24. I haven't used anything aside stainless steel in TC I have attempted to use NI200 on sub ohm tank but that doesn't seem to work right either
