Hi Chunky... sorry, but why not? The curve seems to be used by del DNA75. I modified a curve manually to perform a test and the battery indicator appears to follow the direction of the curve... I misunderstood something? Thank you.
Hi All, In some tests with escribe, under equal conditions, the temperature control appears at DNA75 Vs DNA200 with slightly different response. It seems that in the DNA75 the temperature line is more stable. It 'a different management due to the firmware? Both the graphics are made on equal terms and same settings (escribe) with the same atomizer (coil SS316L) and they were repeated with the same results with other devices. DNA75: DNA200: Thanks for your reply or your suggestions
Hi, With Escribe, have you changed something in the section: Device Monitor -> Charging Option -> Set USB Current Limit? If yes, yon can run the: Device Monitor -> Charging Option -> Reset USB Current Limit. Good luck PS: Obviously, you've ensured the three cells are in perfect condition
