DrDitto
DrDitto's Achievements
  1. Hi James Sorry for delay in my response Actually my Debeian comes from a minimal install using the netinstall iso. Than later receive a Plasma gui via taslsel.
  2. Hi, Finally y get access to escribe Thanks a lot for all the supplied help
  3. Hi James I run this to get pkexec But where can i find the 60-dimension_engineering.rules
  4. Hi James, Thanks form you fast response user is part of group but there is no files in /etc/udev/rules.d and also there is no /usr/bin/pkexec How can i fix this issue?
  5. Hi I am getting this message.... Any idea of how to workarround this message Debian 13
  6. The main problem is the battery sled, is pain in the ass. ther is no space to use the recomended wire gauge. Let me figure out a solution as soon as i get i will post it
  7. There is a lot of work, yes, the main problem is that original battery sled does not allow the use of propper gauge cables.
  8. First First. The button does not work the fire switch requires that the button will be filled with epoxy or solder in my case Second the recomended wire gauge requires tweaks. Mi solderin skills are not the best, but no bidged solders. Battery sled requires hacks
  9. Actual status 510 replaced battery sled work in progess, it requires re wiring
  10. The board arrives todat
  11. I order a dna250 board from protovapor last thuesday, I live at Costa Rica. As soon as I get it, I wiil document the complete process: Disassembly510 changebattery tray wire changebalance tab wiringRe assembly
  12. Board Incomming!! As soon as I get I will take the pictures of all process. Step by step
  13. The main problem with rx 2/3 ismael the 510 And the small gauge cables. The only way to fix that crappy construction ismael relación the 510 Android use the proponer wires suggested bytes evolv
  14. The rx2/3 screen has a diferent connector
  15. Thanks a alot VapingBad for the feedback on this convertion
