kentam
  • Full Name
    Ken Tam
    China
    REULEAUS
kentam's Achievements
  1. New bug. When you copy the profile and the materials will have a duplicate entry. i.e. if the profile have watts after copy... The materials list will have 2 watts.
  2. I want this feature too. DNA programmer should consider this by add a flag field.
  3. Anyone have the unit, and can test with .00088 ? and confirm it will work? What to order one if work, Many thanks.
  4. I don't sure if fire it with a jet lighter will do the job, it will be shape after dry burn, and better have tools to mod the shape during it is super hot after red.
  5. ok I put a very short NI200 in a old kennedy rda, and the ohmmeter measure is 0.01 and aa is show 0.0099 show my mod res is set correctly.
  6. No, sorry for make you confuse... They are other mod with different chips I just use that to proof the build is solid.
  7. Thanks for dwcraig1 My coil in the tank is SS430 28g 2.5 12warps ohm meter = 0.89 mod 1 = 0.88 mod 2 = 0.9 mod 3 DNA 200 with Amotizer Analyzer = 0.961 (jumping up and down in very small margin) mod 3 DNA watt fire = 1.11 ...strange?
  8. Anyway thanks for your feedback / reply.
  9. Thanks VapingBad, Can you give me some source of SS430 profile / TFR / curve? Now I am using cvs from steam engine.
  10. Hi All, I am new to DNA 200 with SS430 wire. My current situation is my coil build as say 0.88 ohm, and if I fire it in DNA 200 watt mode LCD show during fire is start from 1.1ohm, but the Atomizer is showing lower than 1.1ohm feel strange. I use SS430 mainly want to make the TC work, because I am a bit afraid the side effect of NI200. So most my try and error is in tc mode. In tc mode. If I lock the coil ohm by software to 0.88, the mod will just fire in a very weak power. But if I add up some small margin... say a 0.5 ohm coil lock as 0.58 and a 0.88 coil lock as 1.1 it will fire up normally. Anyone have same experience? I do want to hear what you think and how you resolve. Many thanks.
