I don't want to be rude but let's try to be professional here. I know about this option - been using DNA & Escribe since the very 1st that came out. This does not solve the issue as the issue is probably coming for the malfunction of the board itself.
Evolv Support provided me also extremely useful information which was to connect to the escribe and set to "removable batteries" ... which is kind of an obvious thing you do once you receive a device which I did long time ago and also is not a solution.
no worries about your english - its perfect I am using ThinkVape 250C. And I followed your recommendation.
1. I applied Service Pack
2. I uploaded default.ecig for ThinkVape
3. I tried waiting with batteries
nothing works
ok, I changed the coils to another company ones.
Now I have a question - so the ohm goes .1 to .15. So those temp sensing coils.
as per the replay it self, when you're looking for your vape - does the Save Puff option appear to you after each and every puff even when you chainvape or it has to be set when the coil is at its' lowest ohms.?
Hi guys,
I am using DNA 250C since yesterday and I got only one issue, while replay sometimes works perfect (I am using the 316L) sometimes it does not fire and on screen there is error message "check atomizer". When I let it sit for a couple of seconds it starts working again as if it needed to cool down. Is that a correct funcionality - I mean you cannot chainvape on it?
Anyone had that issue and knows what might be causing it?
