great, I really appreciate your help. i think this was why this Mod was so different with temperature and watts vs my older one and this is supposedly a much better mod
quick question. this update happened this past Monday so I go to the menu and choose a version before the 16th. Are there any other steps only because I am not in front of my computer as we speak. Lastly as I make the change should my Mod be connected?
Hi, i think i did this as well. so i choose any version before Feb 16 2016? This could be why I am having issues on anew DNA 200 mod I just bought vs my some what older one that fires much better at lower temperatures and watts and I am now alos not able to taste the flavor vs when I put it on my other DNA 200 which i have not connected to this new download? Please advise. Thanks
Thanks. I always clean my tanks. maybe Ill try a new package of coils. It just seems odd that on every Mod I have (over 10) including the other DNA 200 its just very consistent regarding watts and temps, depending on which tank and coil type I use. I pretty much know where to initially have them set and usually its just minor tinkering of a few watts and 10-20 degrees F here and there. I do appreciate your thoughts....DG
I have an HCigar 133w and just bought the Boxer 133w. I own 8 different tanks and two of them are not working how they work on my other DNA 200 or any of my other higher end Mods. Both my Kanger & Artic horizontal always fire great around 320F-400F "depending on where the battery's are currently at" at 24w to 36w's using NI coils. I do not build my own coils and only buy the pre-made ones. For some odd reason i can not get the Artic to fire unless i raise the Temp to above 500F & the Kanger at 450F+. Also I had to move up the watts to 45 on the Kanger and 60Ws on the Artic. All my other tanks are firing great below 420F and as low as 325F bet 34 & 65w. Even my SMOK TFV4 is firing at 400F 60Ws like a Lamborghini being full throttle punched off the line. I have moved the punch up to 11 and set I have been playing around with the pre heat limit between 7.5 & 2 to try and fix this. Both packs of coils were bought from highly reputable sites and I checked the authenticity code on the manufacturers site Does anyone have any suggestions as I would like to get this corrected? The Boxer is brand new and only these two tanks which i like with certain juices will not work as they normally do. Thanks
