mojodiscontinuity
Everything posted by mojodiscontinuity
Vaporshark dna200 - resistance reading high and very hot vape.
mojodiscontinuity replied to Angus337's topic in Report a Bug
What TFR/CSV are you using? I believe Triton Coils uses SS316L, if you try to use the TFR/CSV SS316 or SS304 in your custom profile it could throw your temperature curves off for that coil. -
Thank you for sharing!
None that I'm aware of. Still, the Steam Engine TFR for 304 Stainless Steel has been working beautifully for the crown SS coils in the DNA200 TC Mode. I'm not sure were the previous poster got the information about "Nickel Legs" in the crown coils (a link to the source info would be nice), but from the coil tear downs I have seen thus far on YouTube, they seem to be made of one single material. EDIT: There actually is a link posted by VapingBad with more info in the UK Vapers Forum. I'll repost it here for convenience: http://ukvapers.org/Thread-New-DNA200-mod?pid=1400866#pid1400866 Also, if I come across a YouTube vaper that runs an actual oscilloscope test on the DNA200 using SS_304 such as pbusardo or DJLSB Vapes, I'll post the video here.
Temperature control for Nickel coils is ready out of the box for the DNA200, and the vast majority of sub ohm tanks in the market like the Aspire Atlantis/Atlantis2/Triton have prebuilt nickel coils available for TC. Although getting a "dry hit" is much less of a concern on tanks because of the near constant juice feed, it can happen with thicker/higher ratio VG juices and higher wattages when the wicking cannot keep up, or if you are just not paying attention to the liquid level on your tank. For tanks, TC is used primarily for "safety" (Above 600F is where e-liquid breaks down into the nasty/toxic compounds like formaldehyde), but some vapers simply max the power/wattage settings on their devices and adjust the temperature to where they want it to suit their personal vaping preference. With that said, Uwell also has nickel coils available for the Crown tank TC, but at the highest settings for the DNA200 which is 200 watts and 600F, the vapor starts tasting weird, personally speaking. Most YiHi SX 3(xx) Series devices keeps Nickel coils restricted at 50 Joules (though some can go up to 100 Joules if you are using Titanium coils and have a dual 18650 Battery mod). The two Sigelei TC mods go up to 75 and 150 for the single and dual 18650 battery mods respectively and the JoyETech VT goes up to 60W in TC. For me personally about 40-80 watts is the "sweet spot" for nickel coil tanks in TC mode depending on the tank, e-liquid, mod etc, and there's really no reason, for me at least, to ever go above 90 watts using nickel. For coil builders Titanium is starting to gain popularity for TC, as more devices, particularly the YiHi SX 3(xx) ones support Titanium in TC mode either out of the box or with a firmware update. DNA200 can of course support any type of wire, including Kanthal, given the proper TFR inputs, but you need to know how to use the EScribe software to even have that option, and you will lose TC accuracy with certain wire types, particularly with Kanthal wire because of its inherent properties. I set up profiles for SS-304, SS-316, Ti-01 and Ni-200, and a "regular" power mode on my DNA200. IMHO, these modes should be ready out of the box and the "custom" settings should be reserved for dual/hybrid wire builds. Perhaps in a future update.
I didn't know about the Nickel Legs on the Uwell Coils, that will probably change the resistance properties, I guess we will eventually get TFRs straight from the coil manufacturers, so we won't have to "guesstimate" like I've been trying to do to get TC mode to work on the Uwell Crown tank coils. So here's my findings thus far, The TFR for coils made of one material will be the same regardless of all other settings, so you can just go straight to the Wire Wizard, change the drop down to the desired coil material, click "DNA200", leave everything else at the default values, then click "Download TFR Table as CSV." With that said, the wire wizard is there to help calculate the resistance and the TFRs of 2 different material wires, like a parallel or clapton coil build using separate Nickel and Kanthal wires. The .CSV file can be loaded into a DNA 200 profile using EScribe. I also learned that the steel used in the Uwell coils is actually 304 SS and not 316L, at least according to D. Jaquith, who made a guest appearance on The Vapor Chronicles. https://www.youtube.com/watch?v=lVSRLPgD7GY Using the 304 SS TFR in the DNA200 for the "0.25 ohm" Crown Coil. I was able to get a better vape at a higher Temperature cutoff compared to the 316 SS TFR. Anecdotally speaking, I felt I had to set the temperature to the max 600F when I was using the 316 SS TFR on the DNA200/Uwell Coil, while the 304 SS was much closer to the DNA40/Nickel performance. When I set it to 600 F, the vape was hot, but not unbearably so. If anyone wants to try TC with a Uwell SS coil on a DNA200, IMHO the 304 SS TFR is the way to go, at least until Uwell releases a "custom" TFR, or when vaping hobbyists and/or bloggers start using equipment and recording data on these coils and starts sharing the info with the rest of the vaping community.
It looks like the new Wire Wizard is geared towards coil building, and unfortunately I don't have the exact measurements and numbers of the Uwell Crown Coils to enter into it to get the proper TCR settings for that coil for the DNA200/EScribe software. I might be able to approximate the right TCR based on the Atomizer analyzer reading, and play with the numbers so that it matches the "rest/room temperature" resistance. Originally, I wasn't sure if the Inner diameter, Number of wraps, Leg length and Wrap spacing, etc. ultimately had any bearing on the final TFR result, but I entered the information in 3 different ways (Wire, Parallel and Clapton), mostly "fine tuning" the "Number of Wraps", the AWG and/or the mm Diameter to make sure ultimately that the final resistance matched as close as possible what was being read by the DNA200 board and the EScribe software (0.275 ohm) all for SS316 wire, the final TFR numbers all came out identically. I then went back and punched in the same info. The temperature points were different, so I made sure they were identical in both the old and the new calculators, and the results again were identical. The main difference between the old and the new calculator is the availability of different wire materials. The old one in particular, is missing "regular" SS 316 and only has "Elite/SS 316L" which appears to be a "special/proprietary" wire made by Gplat, so it will have different material properties and TFRs than the regular 316 Stainless Steel. I'm going to try the regular SS 316 and cross my fingers that the presence/absence of the "L" (to make the steel alloy less corrosive) will be negligible in terms of Temperature control. My DNA 200 is charging off a 2 Amp adapter and is nearing full charge so I can start working on it once that's done. I'll try importing the new TFRs for 316 stainless and see if it makes a difference in the TC, vape quality and temperature accuracy on the DNA200. I'll be sure to come back and post my findings...
First of all, greetings. This is my first DNA200 device (HCigar VT200) and thus my first foray into EScribe Software customization and also my first post in this forum. I apologize if this question has already been asked (or if there is a better place to post this question in), but my searches came up dry. I'm trying to set up Temperature Control for the Pre-built Uwell Crown Stainless Steel coils, particularly the 0.25 ohm ones on my DNA200. Since I don't really know the exact coil dimensions to input into the new Wire Wizard, I attempted to generate a .CSV for "DNA200 Output" using the "old" TCR calculator: http://www.steam-engine.org/tcr.asp The following options were used/selected: Temperature points (default): -100,0,70,200,400,600,800Select wire(s): SS 316L / Elite (TFR)Resistance: 0.275 ohms (Top reading of the Atomizer Analyzer)This was the DNA200 output that I downloaded into a .CSV file: "Temperature (degF)","Electrical Resistivity" -100,0.894808435072142 0,0.9588476571924915 70,1 200,1.0721420643729191 400,1.1702552719200887 600,1.2568175278497145 800,1.335482796892342 Which I loaded as a custom material onto my DNA200 via Escribe. As for the Profile settings they are as follows: Power: 120 WTemperature: 500 degFOhms Locked: 0.275 ohmsPreheat Power: 130 WPreheat Punch: 4Preheat Time Limit: 1s Perhaps it's working as it should, but it seems to me that it never hits the high watts like it does in non TC mode. In fact it seems to hit weaker than one of my DNA40 mods in Nickel TC mode. If anyone can give me pointers on what I may be doing wrong or if there's a better way to configure/set my DNA200 to hit 120 watts on Uwell 0.25 ohm SS coil with TC protection to offset burnt/dry hits, it would be greatly appreciated. UPDATE: I manually set the temp at the max 600F and the power at 200 Watts. Although the temperature protection kicks in at around 70 to 90 watts (or so), it definitely provides a strong hit for the tank. I can set the temp lower if I want a cooler vape. Although I have my doubts as to the accuracy of the actual temperature, it's much closer to what I want it to do. I'm keeping the Preheat Punch at 120 since that the "max" watts the coil is rated for. Still, if anyone has any insight on how I can make this more accurate, I'd love to hear from anyone else who has had any degree of success with the EScribe settings. UPDATE 2: If the rest of the thread responses are "TL;DR" for you I wound up using the TFR for 304 Stainless Steel, and it seems to work the best with the Uwell Crown SS coils in Temperature Control Mode. The input variables on the steam engine site are mostly for pre-planning a build. If you are only using only one wire material, the TFR should remain constant. Go into the Wire Wizard page, Select "DNA200", click the desired wire material in the drop down (In my case SS 304), then "Download TFR Table as CSV". That CSV can then be Loaded as "Coil Material: Custom" in one of the profiles.
