Car147
Everything posted by Car147
  1. Just check your dimensions of your current battery in the mod, if they are the same or the replacement slightly smaller it would be fine, and the same would apply for the connectors, as long as there's space for an XT30 all would be good, but i think you may be limited for space so may have to keep the bullet connectors. By the way your English is very good, just wish i could say the same about my French.
  2. Make sure and use spaced coils, especially with SS in TC
  3. A 900mah lipo is not going to give you much vape time at the figures you quoted above, i'd be looking for at least a 1300mah pack, or do a self build if you feel capable.
  4. Cheer's m8
  5. Yup, sorry @Vapingbad forgot to post back. I did as you said and its working fine now, wasn't too bad to do in all honesty. I just had to go easy to make sure i did'nt get it out of shape. Thanks guys!
  6. Cheer's gents, i'll give that a try.
  7. Hmm, same fault again this morning, i also notice in Escribe that there's no change when firing the mod running device monitor, so it does seem like a faulty fire switch, i'll see what Evolv come up with. Not bad on the reliability as that's the first issue i have had in 8 DNA mods (Mixture of 75's and 200's) since they were launched.
  8. Update, when connected to Escribe a window popped up saying there was a problem with some files missing? and requested reverting to factory settings. i did revert back and so far after setting it all up again it seems fine so far, so i'll just keep an eye on it for now.
  9. Cheer's for the reply and info. I should have thought about sticking it on Escribe as that will show straight away where the problem lays, good call. If it does turn out to be the button i may just get one from RS in the UK if they stock an equivalent , but will talk to Evolv beforehand. Many thanks for the help
  10. Hi All I have a problem that's developed in the last couple of weeks with my Efusion DNA200, when i go to fire the device sometimes it will, other times nothing, i am thinking it's fire button issue as the screen does not change as if it had fired. The mods 9 mths old so out of warranty, i might just bite the bullet and throw a 250 in, or try and source the button. Any advice appreciated,
  11. Wbward, do you live in the UK? because if you do the vendor that sold you the mod is responsible for either replacing the mod, or giving your money back with any failure within 14 days of you buying it. they are responsible full stop! not Wismec, or Evolv, it is then up to them to go to the manufacturer (Wismec) to seek recompense. If in the US, i dont know, but would think you still have protection laws just for this kind of instance,
  12. Helped me as i would have been asking the same question at some point.
  13. Very Nice VapingBad.
  14. Hi m8, fancy seeing you here.... Thanks all for the replies, guess i'll likely use the adapter and continue with 18650's
  15. Hi I take it 30amp constant 60 amp pulse, 26650 batteries will be more than adequate for this device? (Hcigar DNA75) is coming using either the current 18650 cell with adapter, or a 26650 cell.
