Dirone, I have been using "EScribe Suite 2.0 SP19" since it first posted eons ago and never had any problems.
Why don't you just give it a try, if it causes you any problems you can always revert back, just make sure you back up whatever you are using now before updating.
Hope it solves your problem.
James,
The only thing I have noticed is SP17 doesn't detect when there is a newer service pack available. I had to load 1_1_SP35_INT.sw-service manually.
DNA 250C
Windows 10
SP17 International Version
gorman,
Boy do I wish I had never gotten into this topic. First I read your post wrong and then when I read Jason's "DNA 75/250C" to mean it works with the DNA 75 . I should give up and just stay quiet.
gorman,
You should give Jason's "Enhanced Default DNA 75/250C theme that is posted; for international firmware" a try. I'll bet that will make your day.
George
Jason,
Oops, I think I read what I wanted to see DNA75C but now I see he wants it for the DNA75. Sorry I led you astray Gorman.
But I'll bet if he follows your suggestion he will have it working in now time.
Maxi,
The 1.2 SP33.2 must be a typo.
Mine loaded: 1.1 SP33.2 also and if you look in the update directory on your computer there is NO version 1.2 SP33.2.
I think James has his hands full juggling a half dozen hardware models and trying to integrate them all into one eScribe package.
Twiq,
Watch the two videos that Retird linked to. If I try to explain it you'll be more confused than you are now.
The new DNA 250C actually uses a 400 watt capable board, Brandon claims the extra head room of the 400 watts can be taken advantage of in "Replay" mode.
Anyway the videos will explain what Replay is.
Oh - And Lost Vape has one that is do to come out any day now. Also the DNA75C will have new software to incorporate "Replay" but not until they finish dinking with the 250C.
Retird,
Thanks for the tip.
That is one of the options I actually read and remembered.
I have watch both videos and now I spend my time searching for the new Lost Vape Mod with the DNA 250C/400C chip-set. :-(
George
Twiq,
I know what you mean about the boost. Most of my dual coil 24 Ga builds are a real pain without boost. I have to take a couple of primer puffs so the third is the puff I wanted in the first place.
Twiq,
I haven't heard of any damage from this problem but charging at 1 amp sounds like a good idea.
Well maybe you'll get lucky and James will catch your post and reply here on-line. He is pretty good at picking up problem post, but considering this is Monday he probably walks into a fair backlog .
Hang in and I'm sure they will fix you up.
PS - Sorry I didn't pick up the firmware update in your screen-shot.
George
Twig,
Did you apply the new firmware update when you moved up to EScribe Suite 2.0 SP12 ?
The new firmware is supposed to fix the problem you are having.
If you have the new 250 firmware and it is doing what you show in the screen capture I would suggest contacting Evolv's support guy and telling him your problem.
George
