Jim1
  • Full Name
    James feinson
    England
    Dna200
Jim1's Achievements
  1. Thank you, that has been a great help. I entirely accept what you say in the second paragraph, however, I've found the voltages quite handy in the past and the input current is handy just to know how fast it will charge. I probably wouldn't do anything if it was charging at 1amp, if it was .4 I might spend the time to find a better charger/charge cable. The same with the voltages, the cells are never exactly the same but if one is at 3.2v and the other two are at 3.8v after a bit of time charging then I know there's a problem which hopefully I can sort out before my commute home. Peace of mind maybe? But it was driving me nuts trying to figure out how to get the screen to stay on so thanks again for the help.
  2. Wayneo, Zark and Retired, many thanks for your time. It is appreciated. I can see the led fine already but I really want a display where, when it's charging, I can just look over and see the input current and the voltage of each cell without having to interact with the device. It's how I have my 250 set up (apart from the input current). Wayneo, you're a star, I've set up a child screen off of the main screen with the toggle and it works. So thank you for the advice. The only problem now is that the screen stays on but also the led is now also permanently on and is blue. I haven't changed any of the led settings so that should indicate it's firing (it clearly isn't) but is there a way that you can think of to either turn it off or have it set to the pulsating red as in the default profile? It's picky I know but I would prefer to keep the led off then have it on for hours at a time.
  3. Make that three, has anyone had any luck with this. Have just built my first 250c and didn't realize how much I used the charging screen on my 250 and 200 until now. Have tried making my own theme with conditions on lock screen but this hasn't worked. Is it possible to keep the screen on when charging?
