I decided to try some Temco Ti grade 1 wire. This is annealed wire, which I did not notice when I ordered it. I searched all over the forums for info on Temco titanium wire and found no mention of it other than questions being asked which were completely ignored. So, for $6 wire (25ft/24awg), I thought why not. The wire arrived and was slightly dull silver in color and not shiny like some of the other Ti wire being sold as vape specific or"specialty". The color/appearance would be due to the TiO2 layer and was otherwise clean and not as oxidized as some of the reference pics I have seen.      I've outlined my experience below:   1. I cleaned the wire with alcohol/cotton and wiped it dry before use.   2. loaded the Steam Engine CSV for Ti grade 1. I could not find any other standard Ti CSV files for testing as those that have been discussed were pointed towards dead links.   The setup was the following: Freakshow RDA; Wismec Reuleaux DNA 200;  Settings were 35-45w with a 60w preheat, punch set to 5 (420 - 500 degF)   The coils were 9 wrap/3mm-ID dual coils: 1 spaced set; 1 set of contact coils         With a temp limit of 420 degF: Temperature went to limit within 1 or 2 2second pulls.  Bumping the temperature limit up to around 480 seemed to work better where I could take several (4 or 5) 2-3sec pulls, but the DNA 200 was pulling the wattage back some to keep it there.   Neither set of coils seemed to have the perceived power of SSV Ti using the same settings. Also, the SSV wire hit temperature as I would have expected, when the cotton began to become dry from use, whereas this wire had the tendency to hit the temp limit quickly.   Obviously I will need to order non-specialty Ti grade 1 wire from a few other vendors to know how Ti is going to perform. For me the SSV Wire works very well, but I would like to have a less expensive option.  Also, from what I have gathered, grade 1 Ti  is not commercially available as 100% Titanium and is only 99.2-99.5% pure.  I have seen the 100% pure and surgical grade descriptor thrown around by a several vendors. The surgical aspect would certainly appear to be simple marketing,  as all grade 1 Titanium is surgical grade as are several other grades of titanium.   So for now, I'm going to leave this wire alone, at least until I find out if this is safe to use or not.
