***POWER MODE ONLY!!!***
This theme is simplified for Power mode users only. No Temp, no Replay, just Power. I used the Material Dark theme by Tad as a base but made many modifications to it.
Boost, and Punch are all found on the Atomizer settings screen.
Option to display coil resistance on main screen instead of voltage is in display settings.
***Make sure your profile is set to Wattage mode in EScribe if things aren't working properly!***
What's New in Version 1.1.4 See changelog
- Added toggle in display settings to display coil resistance on main screen instead of voltage
- Moved clock settings to system
With version 1.1.4:- Download
