This is a template for DNA75C and DNA250C! Replay menus. The memory is filled to the limit. Sorry if something is abbreviated or omitted, but there is no memory - all squeezed up ..
99.5% is the memory limit, and 0.1% more is not upload to board.
The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution.
Copy from VapingBad
The TP icon:
default shows on image,
Text status:
Temp Field:
atty\temp as default
Extras:
In Lock Screen down: Current in charge or root temperature in non charging mode.
In Main Screen two resistans: locked ohms and life ohms.
In Main Screen right to Power: temperature of board or output voltage in VW mode.
In Main Screen right to Temperature: Temperature ot last puff
