This is the stock theme with extras hence SuperStock. I couldn't find a theme I was looking for so I made my own.
On the Lock screen I added the current wattage it is set to. I also added battery voltage.
I'm coming from the GeekVape L200C and previously the L200 and was spoiled with all the data that is on the main screen so I figure I emulate that for the Hadron Plus (DNA 250C)
The Main screen I added atomizer amps, and volts. I also added a puff counter and timer. at the very bottom that has no label is a USB voltage and board temperature.
everything else is stock, just the way I like it.
Edited by SoccrStar
wrong file uploaded
What's New in Version 2.0.0 See changelog
BUG FIXES
Bug Fix: Fixed the bug fix that gives you an error when hitting back
CHANGES AND ADDITIONS
- Change time size from big to normal
- In Puff Info: minimized graph, moved current fields up to add a reset puff count option
- In Puff Info: added a Puff Counter
- In Puff Info: adjusted left and right arrows a little farther towards the edge
- In settings: shrunk other menu options to add Recording. That'll take you to recording screen
- In settings: changed Atomizer to Main Profile
- In settings: shrunk other menu options to add About
- In settings: shrunk other menu options to add Patent
- In settings: Put menu options in order with back at the very bottom
With version 2.0.0:- Download
