Copyman's Lostvape Hyperion/Centaurus extended - DNA75C/100C/250C 1.5.0
   (0 reviews)
Information:
The theme is based on my previous themes. It works on DNA75C, DNA100C, DNA250C, and in DNA75C/DNA100C does not operate "Power bank" mode. Supports replay.
On the idea of vapingbad - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution.
Preheat:
Preheating has several states: 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false.
The TP icon:
default shows on image,
Text status:
Temp Field:
atty\temp as default
Extras:
There are two main screens - extended and easy!
In Lock Screen down: Current in charge or root temperature in non charging mode. When using a power bank, an icon is displayed.
In Main Screen two resistans: locked ohms and life ohms.
In Main Screen right to Power:  temperature of board or output voltage in VW mode.
In Main Screen right to Temperature: Temperature ot last puff
In Main Screen top:  The name of the profile below is the material used
In Battery Screen: Below is shown what current is the charge, and the displayed power indicates whether the fast charge is on: normal charge - 7.1 watts / fast charge - 13.2 watts (approximate values)
Main screen's:
                Extended 1                                 Extended 2                                                  Extended 1                                  Extended 2                                  Extended 3
Centaurus-main-1.png.2da69dc9730f89556b6bc989519bc3d1.png  Centaurus-main-2.png.c356adc1882e13901fcb44c6dec1c2c4.png           Hyperion-main1.png.3b77a9868537828123c9f357d7316c52.png  Hyperion-main2.png.7c467580188cd08fbd0350165b9ad480.png  Hyperion-main3.png.e87e49b413e68d4318f9c5a3a899d3e2.png
*** Only the Centaurus theme has a reworked battery display for now:
Easy main screen:
                     Centaurus                                      Hyperion
Easy-main-Centaurus.png.96bf11344991f39fb371b16bea346824.png  Easy-main-Hyperion.png.3cd677801be68d8a39a47bc122d0e87c.png
Edited by copyman
text editing
What's New in Version 1.5.0   See changelog
Fixed a bug in the date of the lock screen.
