atti84 Posted June 3, 2024 Report Posted June 3, 2024 (edited) I have been playing around with my dna60c's for a few weeks now and encountered a couple of problems that someone may be able to help me out. First of all there is no power lock option. There is no sequence to set on escribe and if you put the power lock option directly on the theme it does absolutely nothing. Second, while I am able to set a lock sequence directly from my theme, I am not able to put an unlock sequence. It will let you do it on escribe but I would like to have it directly on my theme since I do not have usb ports and every time I access escribe I have to get access directly to the boards. Thanks for your help! Edited June 3, 2024 by atti84
0xstarto0 Posted December 22, 2025 Report Posted December 22, 2025 I have been playing around with my dna60c's for a few weeks now and encountered a couple of problems that someone may be able to help me out. First of all there is no power lock option. There is no sequence to set on escribe and if you put the power lock option directly on the theme it does absolutely nothing. Second, while I am able to set a lock sequence directly from my theme, I am not able to put an unlock sequence. It will let you do it on escribe but I would like to have it directly on my theme since I do not have usb ports and every time I access escribe I have to get access directly to the boards. Thanks for your help!
