EatingPattern Posted October 21, 2021 Report Posted October 21, 2021 (edited) Hello! I've been using DNA chipped mods for traditional Nic vaping for a very long time. The last couple years I've also been using them for sub-ohming cannabinoid distillates as well. The DNA chip in Replay mode does an admirable job protecting the coil from running dry even when vaping near solids (at room temp). Even so, when colder winter environments are involved, it's a lot to ask of the device. Is there any settings I can manipulate to get a "Lower than set wattage" preheat to bring my oil up to temp (and viscosity down) before it ramps up to vaping wattage? The best I've been able to manage is to just create a completely separate "Low wattage profile" just for doing this, then switch back to my replay profile, but that's a lot of fumbling around on the menu each time. Thanks for letting me pick your brains! Edited October 21, 2021 by EatingPattern
CMK Posted October 21, 2021 Report Posted October 21, 2021 vor 8 Stunden schrieb EatingPattern: The best I've been able to manage is to just create a completely separate "Low wattage profile" just for doing this, then switch back to my replay profile, but that's a lot of fumbling around on the menu each time. Hi, in my themes ("2 in 1" and "Basic"), AFTER saving a puff in REPLAY mode, you can adjust the performance downwards at any time without losing the saved move. After you have brought your liquid up to temperature, you increase the performance again above the previously saved limit and leave the control to REPLAY again. During this process (in my theme) REPLAY is not deactivated; So do not "Cancel" and reduce the power, but in REPLAY mode reduce the power - temporarily - manually.
CMK Posted October 22, 2021 Report Posted October 22, 2021 Am 22.10.2021 um 01:08 schrieb CMK aka gwyar: ... my themes ("2 in 1" and "Basic"),... My "Basic" themes are no longer available for the time being, I was just not satisfied.
CMK Posted October 26, 2021 Report Posted October 26, 2021 Am 22.10.2021 um 01:08 schrieb CMK aka gwyar: Hi, in my themes ("2 in 1" and "Basic"), AFTER saving a puff in REPLAY mode, you can adjust the performance downwards at any time without losing the saved move. After you have brought your liquid up to temperature, you increase the performance again above the previously saved limit and leave the control to REPLAY again. During this process (in my theme) REPLAY is not deactivated; So do not "Cancel" and reduce the power, but in REPLAY mode reduce the power - temporarily - manually. You can also use this new theme from Gatok
EatingPattern Posted November 17, 2021 Author Report Posted November 17, 2021 (edited) On 10/25/2021 at 11:09 PM, CMK aka gwyar said: You can also use this new theme from Gatok So sorry to not reply for so long, had a lot of stuff going on. Thank you so much for taking the time to link those for me CMK! I will absolutely go play with those themes. Thanks again! *Edit* It appears I am already enjoying one of your themes (Enhanced 2-1 Thelema) on my Thelema that I primarily use for Replay on small SS MTL coils. Wonderful theme. I love how it shows me what Wattage the chip has chosen for each puff based off of my settings. At least I think that's what it's doing? I'll never fully be able to wrap my brain around what Replay is doing lol. But very cool theme, thank you! Edited November 17, 2021 by EatingPattern 1
