Does anyone have any experience using these on the DNA GO? I’m loving them as I really did not care for any of the .25, .5 or 1.0 stock pods for nic salts (25-50mg). I find the flavor to be much better but I am going through pods faster I feel. Any tips on settings? I did lower them a bit and only have boost on lower setting and warmth set to 1 I believe. Any help would be much appreciated.
  • 3 months later...
I use them on a regular and they're awesome.  I find that they last me much longer if I step up wattage when they're new to break in, use the same flavor on the refill, and do only mouth to lung draws.  I usually do around 8 to 10 draws before going to the next setting. I only do mouth to lung because that way I'm force to do shorter draws which have a less chance of getting dry hits and burning your cotton.  I also hold it button side out so that when I tip to draw the juice will go towards the coil, incase I'm low on juice, to avoid possible dry hits. The 0.3 ohm doesn't really need any setting changes in my opinion but the 0.8 did so it would last longer. I do the 0.3 at my 4th setting instead of the 5th which is my highest. I also use it about 50/50 when it comes to replay mode and I can tell a bigger difference with the older the pod gets. Here are my settings for the 0.8 ohm. These pods aren't made by Lost Vape. They're made by IQS who also makes the Squid Industries Orchid mesh pods.  https://www.evcigarettes.com/the-pod-iqs-mesh-coil-orion-dna-orion-q-pod-replacement-2pcs/
Watt: 10, 12, 15, 17, 20,
Boost: 2, 2, 2, 2, 2 or 4, 3, 3, 3, 3 depending on the juice or mood
Warmth: 1 - 5 typically 1 or 2 for mine
There are plenty of more websites to buy them from and even some shops. I carry them at my shop for only $10.50 for a two pack. Very nice price point.
