kambiing Posted October 2, 2018 Report Posted October 2, 2018 I have problem with the contact (maybe), I am looking information how to disassemble this thing and fix the contact. I see the negative contact is spring loaded and the box may be opened by holding it and removing the bay. Problem is the spring is very tight, i have no idea how to do so.
ozzyag Posted March 6, 2019 Report Posted March 6, 2019 On 10/1/2018 at 8:14 PM, kambiing said: I have problem with the contact (maybe), I am looking information how to disassemble this thing and fix the contact. I see the negative contact is spring loaded and the box may be opened by holding it and removing the bay. Problem is the spring is very tight, i have no idea how to do so. Just took mine apart. Start by getting both screws inside the battery compartment. Then start by pulling in the bottom until you get some wiggle room. The what I did was grab my smallest flat head screwdriver and kinda went around the mod and popped out the part of the battery compartment that should become obvious that it’s the part that should be coming out. After that it’s easy peasy
